608
Highlighted
Cisco 5520 WLC not booting
Hi Guys ,
We have 2 Cisco 5520 controllers in HA for our infrastructure , i am facing a serious issue regarding secondary  Controller as its not booting after a power issue . Its giving the attached messages on the console . I will appreciate if you could suggest whats the exact problem ( hardware failure etc )and how i can resolve it . Please find the attached messages which i am getting on console . Hope i will get the guidance from our Gurus .
Regards ,
Muddy
Everyone's tags (1)
5 REPLIES 5
VIP Advisor
Re: Cisco 5520 WLC not booting
Is that  boot process stuck there for long ? if so please raise a TAC case.
BB
*** Rate All Helpful Responses ***
Hi Balaji ,
Thanks for your response , its getting  stuck for 10 minutes and than  restarted and came to the same place where it was stuck before .
Regards ,
Muddy
Hi Guys ,
Balaji have suggested i should contact the TAC , can i get some more insights regarding this , appreciate if any Cisco Employee can guide about this also .
Thanks and Regards ,
Muddy
Beginner
You either have a corrupt image now or its hardware damage.
TAC will be able to assist you with either one. If you don't have smartnet you may be able to try and RMA it under a limited lifetime warranty.
Hi Adam ,
Thanks for your reply , yeah its a hardware issue .
Content for Community-Ad
August's Community Spotlight Awards
