09-16-2005 07:00 AM - edited 07-04-2021 11:08 AM
Hi to all.
I have configured the wireless part of my router 877W. Right now i am using WEP only but i want to setup WPA (with pre shared key) for a more secure access. I am a wireless noob and i haven't much knowledge about this configuration process / options.
Please can some one tell me the correct steps to configure a working WPA authenticated wireless lan with a simple WPA-PSK key (not radius)?
I was using Web interface (Wireless security Express option of the Wireless WEB application) for the confguration not IOS CLI commands.
Thank you very much.
Solved! Go to Solution.
09-17-2005 05:51 AM
Set the Security|encryption | Cipher for AES + TKIP
Set Security | SSID Manager | Methods for "Open" (only)
Check the box for Key Management for "mandatory"
Check the box for WPA
Enter a Key
As with WEP, the keys on the AP and the keys on the clients must match exactly (case, spaces, everything).
Good Luck
Scott
09-17-2005 05:51 AM
Enter a Key
Good Luck
Scott
