Beginner
Cisco 887VAW
Hey Guys
I have just setup my new cisco 887 wireless embeded router. I'm finding clients have very poor wireless signal strength. All client machines support G only. Do i have a mistake in my config or do these routers have very poor wireless.
Any help appreciated.
Luke
dot11 ssid myssid
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 mykey
dot11 network-map
username admin privilege 15 secret 5 mypass
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
ssid lovellrs
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.100.254 255.255.255.0
no ip route-cache
ip default-gateway 10.0.60.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Cisco 887VAW
Hi Luke,
You made a site survey?
What is the distance between the poorly connected clients and the AP?
Try applying this command under the radio interface:
channel least-congested
This will choose best available channel to use. If the problem persists then you better check your RF noise and/or interference.
Amjad
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
Rating useful replies is more useful than saying "Thank you"
3 REPLIES 3
Highlighted
Cisco 887VAW
Hi Luke,
Amjad
Highlighted
Beginner
Re: Cisco 887VAW
Thanks for the info, I will give this a try. I have not completed a survey but have no interfernece on the channel selected. The issue i have is this router replaced a standard linksys home grade router. I have had to reinstall the linksys as it provided better coverage with the exact same channel, encryption etc.
The distance is about 10 metres but through a few solid walls. The ap works fine when you are in the same room. But when in the distant room it connects at 54mb then drops back to 36mbps then seems to just start dropping packets while still reporting as being connected.
Highlighted
Beginner
Re: Cisco 887VAW
Luke,
I just replaced on of these. Our end user had this deployed in their home and they somewhat worked while in the same room as the router but once leaving the room their ping times (to the router) went from 30ms to 1500+ ms.
At that time I was also running Cisco spectrum expert and there didn't seem to be any interference I could see. However I am fairly new to all of this.
I ended up opening a TAC case and they shipped a replacement router. I put it in place with the exact same config and haven't had any issues since.
So if you find no wireless problems you could try replacing the router with a known working one if you have one.
Aaron
Content for Community-Ad
August's Community Spotlight Awards
