Cisco 9800CL as N+1
dbartwal2015
Hi Everyone,
Can Cisco 9800CL be configured as N+1 for the WLC 3504?
Are there any limitation on it?
Deep Bartwal
balaji.bandi
As per my understanding, you always need N+1 same hardware model with the same version of code.
BB
Haydn Andrews
Short answer is no.
Reason: The software versions on the 3504 (AireOS) and the 9800 (IOS XE) would mean in an N+1 state all the APs would download new code and be offline for potentially 15minutes in the even of a primary failure, and then do the same when the primary comes back.
For N+1 you always want the same software version on both controllers. You also want the same capacity as well to be able to support all APs failing over
*****Help out other by using the rating system and marking answered questions as "Answered"*****
