08-20-2012 11:48 PM - edited 07-03-2021 10:33 PM
Hello all.
Just got Cisco AIR 1142N, configured it with two ssids on 2.4 Mhz interface. 5.0 is shutdown. As I know (probably I am wrong) wireless speed with "n" mode devices must be at least 150 Mbps, but I get only half of that- 72 Mbps. Where could be a problem?
Tested it with notebooks with Broadcom 4313 adapter.
I have read some people face problem with 54 Mbps speed, but they just have wrong authentication.
Be glad for any advice!
and here is a bit of my conf.
Solved! Go to Solution.
08-21-2012 03:42 AM
If your seeing actual 72mbps speeds, then that is correct. If your looking at a device connection speed, then 144mbps is the max you will see on the 2.4ghz and half of that is your max throughput you might see. If your not seeing 144mbps and your next to the AP, then test with a different wireless card and see. Maybe update your driver also.
08-22-2012 06:41 AM
It wouldn't be caused by mutlipel SSID, as the AP will only talk to one client at a time.
Take a look at the specs for the chipset in the laptop. you need to look at how many spacial streams it can handle, as well as how many antenna leeds are connected.
if you are getting better than 54Mbps, you are getting N rates, but limitations to the chipset can keep you from achieving the maximums for the frequency.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
08-20-2012 11:54 PM
Make sure you are using either one of the following:
1. OPEN authentication; or
2. WPA2/PSK
08-21-2012 12:05 AM
leolaohoo
Yes, I'm using this authentication, as it is in my config, exactly this:
dot11 ssid guest
vlan 5
authentication open
authentication key-management wpa version 2
mbssid guest-mode dtim-period 1
wpa-psk ascii 7 *****
encryption mode ciphers aes-ccm
08-21-2012 03:42 AM
08-21-2012 06:43 AM
Maybe I messed up a bit.
I'm looking in 'Status' of wireless connection in Win7, where it tells me that 'speed' is 72 Mbps.
And when I looked on the ssid in wi-fi ananlyzer app (inssider) it tells that Max Rate is 144. So maybe it is really all fine.
And yes, I am sitting next to the AP.
Can you suggest any tests to check connection speed?
Thanks for reply.
08-21-2012 06:56 AM
in Windows 7:
Right Click on the Wireless Bars in the tool tray
Open Network Sharing Center
Right hand side, you will see your internet connect, click on it
You will see your PHY rate there
hope this help
Please rate helpful post!
08-22-2012 06:35 AM
This is what I get, never better speed, sometimes 64.
Can it be because of two ssids?...stupid idea though.
08-22-2012 06:41 AM
HTH,
Steve
08-22-2012 06:58 AM
Yeah..I think this is the problem.
My wi-fi adapter in notebooks is Broadcom 4313b/g/n and this is what I find about it..
Broadcom 4313GN 802.11b/g/n WiFi Adapter | Integrated support for 802.11 b, g, and n 1 transmit, 1 receive antenna Up to 72 mbps data rate |
Very sad.
Thanks everyone for the help and detailed responses:)
08-21-2012 05:53 AM
To get N speeds make sure that you have WPA version 2 with AES only, also remmber that wireless is a shared medium and half duplex.
When you are chcekcing on the speeds how many wireless clients are connected to the same AP at the same time?
08-21-2012 06:46 AM
Yes, authentication is correct (as I said before:) )
I think, sadly I'm not understand fully about 'shared medium and half duplex' bit.
Not much, about 35-40 clients.
08-21-2012 06:51 AM
Hey there ..
Wireless is like a HUB. Only one device can talk on channel at a time, with this fact, its half duplex. Make sense?
08-22-2012 06:33 AM
Honestly, not much sense to me:)
I'm really a newbie to this, still can't understand why I get half of possible speed.
Sorry for kinda dumbness.
08-22-2012 12:07 AM
What kind of traffic? Email? Web? Video?
What kind of uplink do you have? 10/100/1000Mbps?
08-22-2012 06:31 AM
Half are mobile devices, half business notebooks with all kind of traffic, internet\email most, video less, but no VoIP.
Does it make any difference?
AP is connected to 1000Mbps.
