02-07-2015 02:48 PM - edited 07-05-2021 02:27 AM
Hi all.
I have acquired a used AIR-SAP1602I-A-K9 that came with a existing configuration and a secret password.
I have tried to search the web for a guide on howto reset the password / reset factory default so i can clear config and
set a new password. I find a bunch for routers by changing the registry but nothing for AP specific, but i wonder if the procedure is the same?
Anyways i tried to boot the device and break its boot sequence, ctrl + break (didnt work), ctrl + c (didnt work). But i have not gotten far in my
endevour to get control of the device.
Anyone who can share a word of wisdom with me, will be meet with appreciation.
Thanks on advance.
02-07-2015 02:58 PM
Try to follow the procedure in this link:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/15_2_4_JB/configuration/guide/scg15-2-4-Book/scg15-2-4-chap4-first.html#pgfId-1213233
-Scott
02-07-2015 03:29 PM
Thanks for the reply Scott.
I tried your suggestion
IOS Bootloader - Starting system.
FLASH CHIP: Micronix MX25L256_35F
Xmodem file system is available.
flashfs[0]: 194 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31936000
flashfs[0]: Bytes used: 12173312
flashfs[0]: Bytes available: 19762688
flashfs[0]: flashfs fsck took 14 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: a8:0c:0d:9e:70:18
************* loopback_mode = 0
button pressed for 20 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap1g2-k9w7-tar.default
examining image... ************* loopback_mode = 0
%Error opening tftp://255.255.255.255/ap1g2-k9w7-tar.default (connection timed out)ap:
ap: en
Unknown cmd: en
ap:
02-07-2015 03:43 PM
If you hold the mode button too long it will bring you into ROMMON mode which you are in. You can issue these commands:
02-08-2015 02:23 AM
Will these commands delete stored config and bring back factory defaults?
02-08-2015 06:34 AM
If you search on Google for 'Cisco autonomous password recovery' there are links that will help including this one:
https://supportforums.cisco.com/document/12125851/password-recovery-autonomous-ap
There are also links on factory defaults that can help. If that is a used AP, factory default it and start from scratch to ensure that the config is right for you.
-Scott
02-08-2015 06:35 AM
Yes it will.... But delete the config.txt also
-Scott
02-13-2015 05:05 AM
Hi Scott.
Im sorry for the late response, your solution worked and i was able to factory default the access point. I thank you for your time and effort.
02-13-2015 05:08 AM
No problem.
-Scott
03-06-2015 10:51 AM
Scott will this process work with an AIR-CT5760 wireless controller? I can't fine and password recovery information on this AP controller. Thanks in advance for any help you can give me.
03-31-2015 01:29 AM
Thanks for your solution, but it seems not to work for my device.
the first time, i did two fommands "delete flash...." that's ok, but cannot boot. and the next times it shows:
ap: delete flash:private-config
Are you sure you want to delete "flash:private-config" (y/n)?y
File "flash:private-config" not deleted -- no such file or directory
ap: delete flash:private-multiple-fs
Are you sure you want to delete "flash:private-multiple-fs" (y/n)?y
File "flash:private-multiple-fs" deleted
ap: boot
Loading "flash:/ap1g2-k9w7-mx.152-2.JB/ap1g2-k9w7-mx.152-2.JB"...#############################
File "flash:/ap1g2-k9w7-mx.152-2.JB/ap1g2-k9w7-mx.152-2.JB" uncompressed and installed, entry point: 0x100000
executing...
Error loading "flash:/ap1g2-k9w7-mx.152-2.JB/ap1g2-k9w7-mx.152-2.JB"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
--and of course, it requires me password for enabling. anyone has solutions for that?
Thanks in advance.
03-31-2015 06:57 AM
So when you try enable mode, you use Cisco and that doesn't work?
-Scott
03-31-2015 07:34 AM
oh.. i forgot this clue. it worked. i had typed this Cisco many times before making this change, so that made me forget. thanks once again.
03-31-2015 08:27 AM
No problem.
-Scott
02-09-2015 09:44 PM
One end of a console cable is connected to the your laptop's, say, COM1 port ,and the other end of that console cable is connected to the the Access Point's RJ-45/Console port.
Assuming, that the IP Address of your laptop is 192.168.28.2, we use the command below:
ap(config)# copy flash:configBackup.txt tftp://192.168.28.2/configBackup.txt
Now, you have the backup of the existing configuration of your Access Point in C:\ of your laptop.
Open, say, Notepad, and open C:\configBackup.txt, and where you see the text as "username", replace it with the following text , as per your wish:
' Username <your username> privilege 15 password 0 <your password> '
