03-09-2020 06:59 AM - edited 07-05-2021 11:50 AM
Dear Team,
I have a Cisco Aironet 1832i that has been working as expected.
Two days ago the LED of the access point turned red.I have done a reset of the access point using the mode button but it now turns green for a few mins then back to red.The client also claims that the primary controller which is also a Cisco Aironet 1832i is not broadcasting the SSID.
Kindly assist on this.
03-09-2020 07:28 AM
03-09-2020 10:35 PM
03-10-2020 04:15 AM
03-16-2020 01:25 AM
Dear Team,
I took out the access point from the client's site and went back with it to the office.
I setup the access point via cisco mobility express and I was able to use it both as an access point and primary controller. What I suspect could be happening is that the access point is trying to join the primary controller and is unable hence the red led status.
03-16-2020 07:01 AM
03-17-2020 12:05 AM
In hindsight I should have checked at the client site. The other access points( which are also cisco aironet 1830s) are working well.This access point was also working well up to a week ago. I was going through the manual and it says that when its chirping in red that the access point has primed to the wrong regulatory domain.
How would I rectify this since?
03-17-2020 03:10 AM
