7757
Cisco Aironet 2600 Series DHCP Server Configuration NOT Serving Addresses?
I have (2) AIR-SAP2602I-A-K9 similarly configured,
on two different isolated LANs.
They don't appear to be handing out addresses via DHCP.
{If I connect them to a LAN with a different DHCP server,
   the wireless devices can get addresses
   from that other DHCP server on the LAN, through the AP.}
I followed 12.4.25d.JA.cg.pdf
Configuring the Access Point to Provide DHCP Service 5-22
e.g. 3444-RCS1-AN#show running-config
Building configuration...
version 15.2
hostname 3444-RCS1-AN
no ip routing
ip domain name USH-DM
ip dhcp excluded-address 192.168.29.89
ip dhcp pool RCS1
network 192.168.29.88 255.255.255.248
default-router 192.168.28.1
lease 0 1
interface BVI1
ip address 192.168.28.211 255.255.254.0
no ip route-cache
ip default-gateway 192.168.28.1
e.g. 3444-RCS2-AN#show running-config
version 15.2
hostname 3444-RCS2-AN
no ip routing
ip dhcp excluded-address 192.168.129.81
ip dhcp pool RCS2
network 192.168.129.80 255.255.255.248
default-router 192.168.128.1
lease 0 2
interface BVI1
ip address 192.168.128.171 255.255.254.0
no ip route-cache
ip default-gateway 192.168.128.1
1 ACCEPTED SOLUTION
Hall of Fame Community Legend
Re: Cisco Aironet 2600 Series DHCP Server Configuration NOT Serv
Thats the DHCP Pool range 192.168.29.88 through 192.168.28.95
Well that's going to confuse your clients.
And that's NOT how you configure your "range".   See below:
ip dhcp excluded-address 192.168.29.1 192.168.29.87
ip dhcp excluded-address 192.168.29.96 192.168.29.254
ip dhcp pool RCS1
network 192.168.28.211 255.255.254.0
lease 0 1
6 REPLIES 6
ip dhcp pool RCS1
lease 0 1
The subnet is different.
Your network is 192.168.29.88 up to 192.168.29.95 but your default router is way out.
The LAN address range is 192.168.28.0 through 192.168.29.255 (/23)
The AP is assigned IP 192.168.28.211 with mask 255.255.254.0 (/23)
{Unless I am misunderstanding the documentation 12.4.25d.JA.cg.pdf}
Step 3 ip dhcp pool pool_name Create a name for the pool of IP addresses that the wireless device assigns
in response to DHCP requests, and enter DHCP configuration mode.
Step 4 network subnet_number
[ mask | prefix-length ]
Assign the subnet number for the address pool. The wireless device
assigns IP addresses within this subnet.
ip dhcp pool RCS1
lease 0 1
Yes, of course, you're right.
However It doesn't appear to allow redefining the ip dhcp pool network,
  and I can't seem to find a command that willl clear / remove the pool?
refs:
<http://www.cisco.com/en/US/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/scg12.4.25d.JA-chap5-admin.html#wp1090319>
<http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html>
The answer is: default ip dhcp pool RCS2
(sigh)
However It doesn't appear to allow redefining the ip dhcp pool network, and I can't seem to find a command that willl clear / remove the pool?
Sorry, just saw your post.
Try this:
no ip dhcp pool RCS1
ip dhcp pool RCS1
lease 0 1
Content for Community-Ad
July's Community Spotlight Awards
