Cisco Aironet 2702i-i-k9
Stas Balabanov
I've got this device Cisco Aironet 2702i-i-k9
Web interface is closed - is there a way to enable it (or must I have a console access to it)?
Does this devise work in standalone mode?
Thanks.
Scott Fella
You probably have a lightweight AP so you will not be able to hit the GUI. You need to console into the AP to verify that it is lightweight or not. If it's not, then you will need to configure it and using the cli, is the easiest way.
Simce I believe it is a lightweight AP, you would need to convert it to autonomous in order to use it as a standalone access point. You would need to have access to download the image however to be able to convert this AP. Here is a link:
https://supportforums.cisco.com/video/11928901/lwapp-lightweight-mode-autonomous-conversion-and-vice-versa
You can find more by searching for Cisco lightweight to autonomous convention.
-Scott
-Scott
Here are some other links to configure the AP.
You might want to try this if it's a brand new AP out of the box:
http://www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/8-0/Cisco_Aironet_3700AP.html#pgfId-139705
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap4-first.html
-Scott
-Scott
