09-11-2019 10:27 AM - edited 07-05-2021 10:59 AM
I have a query about this topic "clients simultaneously support" for the Cisco AIR 2800.
I need my that my AP will support 500 clients simultaneously.
Solved! Go to Solution.
09-11-2019 11:14 AM
if you have 500 clients to a single AP, what do you expect as throughput for a single client ? Do you think it is a good idea.
When it come to proper WiFi design, we are tying to limit number of devices (eg 20-30) connect to an AP in a typical deployment. High Density (like stadium) it may be different.
As a number, each radio can handle 200 clients , but you do not want that many clients connecting to given radio
Rasika
*** Pls rate all useful responses ***
09-11-2019 11:14 AM
Rasika
09-11-2019 01:49 PM
Thanks for the lesson :D
09-12-2019 12:05 AM
