10-18-2016 04:50 AM - edited 07-05-2021 05:59 AM
Hi All,
Cisco AP 2802I-E-K9, AP Running Image 8.2.130.0, Couldn't joint with WLC-2504 software version 8-2-130-0.But AIR-CAP2702I-E-K9 can register with WLC and working fine. getting below error from the AP2802I
[*10/18/2016 11:01:43.6373] CAPWAP State: Discovery
[*10/18/2016 11:01:43.6390] Discovery Request sent to 255.255.255.255 with disco very type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*10/18/2016 11:01:43.6398] Discovery Response from 10.10.10.5
[*10/18/2016 11:01:53.0000] CAPWAP State: DTLS Setup
[*10/18/2016 11:01:54.6368] CAPWAP State: Join
[*10/18/2016 11:01:54.6379] Sending Join request to 10.10.10.5 through port 5256
[*10/18/2016 11:01:59.2746] Join Response from 10.10.10.5
[*10/18/2016 11:01:59.2747] CAPWAP State: Image Data
[*10/18/2016 11:01:59.2748] CAPWAP State: Configure
[*10/18/2016 11:01:59.3049] DTLS: packet too old or a replay distance=0, this_se q_num=1, last_seq_num=1
[*10/18/2016 11:02:44.8852] GOING BACK TO DISCOVER MODE
[*10/18/2016 11:02:44.8855] CAPWAP State: DTLS Teardown
[*10/18/2016 11:02:49.6374] CAPWAP State: Discovery
[*10/18/2016 11:02:49.6454] Discovery Request sent to 255.255.255.255 with disco very type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*10/18/2016 11:02:49.6463] Discovery Response from 10.10.10.5
[*10/18/2016 11:02:59.0000] CAPWAP State: DTLS Setup
[*10/18/2016 11:03:00.6204] CAPWAP State: Join
[*10/18/2016 11:03:00.6215] Sending Join request to 10.10.10.5 through port 5256
[*10/18/2016 11:03:05.2748] Join Response from 10.10.10.5
[*10/18/2016 11:03:05.2748] CAPWAP State: Image Data
[*10/18/2016 11:03:05.2749] CAPWAP State: Configure
[*10/18/2016 11:03:05.3029] DTLS: packet too old or a replay distance=0, this_se q_num=1, last_seq_num=1
Keep getting the same error. This is new installation and doesn't have Service contract witch Cisco.
Please advice
Mohamed Nazar
10-18-2016 05:16 AM
paste the output of this commands:
1. sh sysinfo from wlc, also paste the complete boot up-process from AP console.
Dont forget to rate helpful posts
10-18-2016 06:03 AM
04-20-2017 12:53 AM
Hi Mohemed,
i have exactly the same problem, did you find the solution ?
thank you.
10-18-2016 11:02 PM
Hi Sandeep,
Can you help us with this issue please?
Ajin.
10-18-2016 11:14 PM
Hi AJIN,
Normally for Kuwait your AP model should be : AP 2802I-I-K9
and you have AP 2802I-E-K9 -> Normally its for Europe.
10-18-2016 11:19 PM
Hi Sandeep,
So can I change the country in the controller and try associating the AP? Will it work? Is there any other workaround?
10-18-2016 11:25 PM
Hi Ajin,
As Rasika wrote....
AP is also using the wrong port to discover WLC.
Are you using IP helper command and IP forward-protocol udp <5246> command on switch ?
10-18-2016 11:27 PM
Hi Sandeep,
As this is a new setup, the AP is connected directly to the PoE port of the 2504 controller. And DHCP is configured in the switch which is connected to the controller, and no IP forward protocol command is used
10-18-2016 11:30 PM
Hi Ajin,
Its not a recommended solution to attach AP directly to WLC.
If you want to join AP, then you need to setup a dhcp scope on the wlc and make sure that it must be on the same network as the wlc management. The ap will get an ip address from the pool and join the wlc as long as everything else is configured correctly.
10-18-2016 11:34 PM
Hi Sandeep,
Let me give that a try. But I have a 2702I-E-K9 AP which got connected without any issue connecting directly to the controller. The problem is only with the AP2802I-E-K9
10-18-2016 11:58 PM
It appears to me as if the 2504 controller software does not have the correct image for the AP2802, but does have the right immage to send to the AP2702.
in the release notes of 8.0.140.0. the 2800 series is not mentioned (could be cosmetic)?
The following access point platforms are supported in this release:
10-19-2016 12:13 AM
10-19-2016 12:42 AM
Hi Sandeep,
I have reset the controller, configured it with country Germany and timezone Berlin, created a DHCP scope, then connected it to a Cisco switch and also the AP to the switch. This time the AP has joined the controller without any hiccup but both the radios are showing DOWN! Please see the attached screenshot. How can we bring the radios up?
10-19-2016 01:00 AM
Did you try to enable manually to these Radios of AP by going here:
wireless > Access Point > Radios > 802.11a/n/c or 802.11b/g/n then on far right of each a blue drop down arrow box is there click on configure and enable the admin status.
