Cisco AP 3602I convert from lightweight to Autonomous
khalon
Dear
i try to convert AP Cisco 3602I from lightweight to Autonomous but when i change the mode for access point to upload the file from T FTP i cannot ping between Switch and Access point (Time Out).
thanks for your help
Sandeep Choudhary
try another laptop/pc(Also disable local firewall)
here are the methods:
https://www.youtube.com/watch?v=c70mOOpqMsg
https://www.speaknetworks.com/converting-cisco-wireless-access-point-lightweight-mode-autonomous-mode-vice-versa/
Dont forget to rate helpful posts
Dear ,
thanks for your support but my problem is when i reboot the AP to start upload the IOS i lose the ping between the switch and from switch i cannot see the AP this my problem
1. login to AP via CLI
2. Assign IP to BVI interface and Default gateway
3. Ping to Laptop from AP and vice versa
4. If ping is scuessful then strat the image transfer from laptop.
Dont forget to arte helpful posts
m.rana.ku
Step by Step Process has been demonstrated How to of Convert Cisco Aironet 3602i Series Access Point from Lightweight to Autonomous version.
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://youtu.be/O2qNFVZ-KRQ
Requirements:
1.TFTPd64 Server
2.Cisco IOS Software AP3G2-K9W7-M for (C3600 Series AP)
3.The Cisco AP and the Laptop with TFTP server must be in same network.
According to my network setup
Lightweight AP BVI1 IP address is 192.168.1.4
Laptop's IP address where TFTP server is installed 192.168.1.7 [Default Router IP]
First disconnect the ethernet cable from the AP then Press the Mode button and Put back the ethernet cable to the AP and hold the Mode button Untill flash light turns to umber and Once the Lightweight AP goes to online then apply the following commands to convert it to Autonomous version:
set IP_ADDR 192.168.1.4                   [According to my network setup]
set NETMASK 255.255.255.0             [According to my network setup]
set DEFAULT_ROUTER 192.168.1.7    [According to my network setup]
tftp_init
ether_init
flash_init
tar -xtract tftp://192.168.1.7/ap3g2-k9w7-tar.153-3.JH.tar flash:
dir flash
set boot flash:/ap3g2-k9w7-mx.153-3.JH/ap3g2-k9w7-mx.153-3.JH
set
boot
