Highlighted
Beginner
Cisco AP not Joining WLC 2504
Dear Cisco Community ,
Wish you all are fine .
I have cisco 2504 with 50 License and cisco AIR-AP1832I-E-K9 (25) .
Every thing seems to be configured propoerly .
But all the APs are not joining the Controller .
Here is the logs from the WLC , and config file .
the ios is 8.2 for ap
for c2504 is 8.0.115
can any one please inform why this happens and how to solve it.
Really appreciate your feedback .
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: Cisco AP not Joining WLC 2504
you need to upgrade wlc to 8.1.122.0 or newer.
2 REPLIES 2
Highlighted
Beginner
Highlighted
Beginner
Thanks for your reply , solved the problem tried it and it worked !!!
But when i want to login to the network SSID , it doesn't login to the network name .
the network SSID name appears on the Wireless network of laptop etc but cant join the network .
Content for Community-Ad
