Highlighted
Beginner
Cisco AP not joining WLC 5508
I have Cisco 5508 running "8.0.115.0" version . I have tried registering 1602 AP , but its not joining to controller. The seesion is getting closed from controller end. Getting below logs . Please help in getting solution.
*Mar  1 00:00:39.790: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:39.793: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.lthed.com
*Mar  1 00:00:49.796: %CAPWAP-3-ERRORLOG: Selected MWAR 'L&T-WLC-Powai'(index 0).
*Mar  1 00:00:49.796: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Apr 25 13:29:50.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.5.3 peer_port: 5246
*Apr 25 13:29:50.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Apr 25 13:29:51.711: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.5.3 peer_port: 5246
*Apr 25 13:29:51.713: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.5.3
*Apr 25 13:29:51.713: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 25 13:29:51.714: %DTLS-5-ALERT: Received WARNING : Close notify alert from 172.16.5.3
*Apr 25 13:29:51.715: %DTLS-5-PEER_DISCONNECT: Peer 172.16.5.3 has closed connection.
*Apr 25 13:29:51.715: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.5.3:5246
*Apr 25 13:29:51.716: %CAPWAP-3-ERRORLOG: Selected MWAR 'WLC1-T'(index 2).
*Apr 25 13:29:51.716: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Apr 25 07:59:27.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.7.51.11 peer_port: 5246
*Apr 25 07:59:28.474: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.7.51.11 peer_port: 5246
*Apr 25 07:59:28.475: %CAPWAP-5-SENDJOIN: sending Join Request to 10.7.51.11
*Apr 25 07:59:28.475: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 25 07:59:28.673: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 25 07:59:28.818: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 25 07:59:28.831: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Apr 25 07:59:28.832: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 25 07:59:28.902: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller WLC1-T
*Apr 25 07:59:28.961: %LWAPP-3-CLIENTEVENTLOG: SSID LTHE-Mobile added to the slot[0]
*Apr 25 07:59:29.001: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr 25 07:59:29.003: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 25 07:59:29.034: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 25 07:59:31.936: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
1 REPLY 1
Highlighted
Beginner
Did you found the solution/root cause to this?
Kasper
Content for Community-Ad
