ā06-11-2015 06:03 PM - edited ā07-05-2021 03:23 AM
Hi guys, I'm having a trouble. My internet connection was bad days behind and I reseted my DPC3925 and, SURPRISE, the Working Mode selector dissapear and I can't put it in Bridged Mode to use with my Apple Airport Extreme.
thanks!
ā06-13-2015 08:13 AM
I'm also investigating this problem and can't find any reference to it.
I suspect that it has to do with the current firmware.
It is a life-ended product, and, on the user's guide there's no reference to any bridge option, but we know it was there. Also, there is no documented procedure to update the firmware.
The Open Source Disclaimer points to this e-mail reguarding questions about the software.
Btw, does anyone know what is the lattest firmware?
Maybe after resetting the modem, it refreshed its firmware... I guess.
ā06-17-2015 01:09 PM
Same here, the option disappeared and I cannot find any reference to this problem besides here!
ā10-07-2015 01:32 PM
Some news, guys? I still waiting :/
ā09-04-2016 04:49 PM
Is there solution already on this. Can anyone share please.
Ramon
ā06-23-2015 01:30 PM
Please follow the below steps :
Step 0: (Optional) Disable Wireless
Step 1: Have Firefox + Firebug and go to the Maintenance page.
Step 2: Inspect the page with firebug, edit the HTML and find:
<!-- 2 -->
<!-- connection mode -->
(search for ā connection mode --)
Now, above <!-- connection mode -->, insert the following code:
<div id="WorkingMode">
<table class="std">
<tr>
<td nowrap width="95">
<script language="javascript" type="text/javascript">
dw(vbcontype2);
</script>Working Mode
</td>
<td>
<select name="working_mode" size="1" id="working_mode" onchange="selectWorkingMode()">
<option name="router" value=0><script language="javascript" type="text/javascript">dw(vben
<option name="bridged" value=1><script language="javascript" type="text/javascript">dw(vben
</select>
</td>
</tr>
</table>
</div>
You will now have the option to select bridge mode, if you have not set a password on the device, you must do so now in order to hit submit. You modem will reboot and be in bridge mode. To get back to router mode, hold the reset button for ten seconds.
ā06-23-2015 04:27 PM
I tried the method described and had no success.
My results:
- Used firebug as directed;
- Working mode selection appeared, selected Bridged;
- Typed username and password to be set;
- Hit save settings;
- Page refreshed, working mode disappeared (as expected);
- Password was set;
- Modem did not reboot;
- Did a Manual power circle, modem restarted still in router mode;
What should I do?
Thanks in advance,
Daniel
ā08-03-2015 08:39 PM
Guys??? The discussion is not dead!
ā06-24-2015 08:52 PM
ā07-27-2016 01:09 PM
I'm same problem.
ā07-19-2015 10:37 AM
ā06-02-2017 10:58 AM
This is not working for me either. I get the an 403 FORBIDDEN error.
ā05-18-2018 06:12 PM
Same here... help please!
