Cisco Flex 7500 and anchor
lmediavilla
Hello, I couldn't find this on the Cisco Flex 7500 specs
http://www.cisco.com/en/US/partner/prod/collateral/wireless/ps6302/ps8322/ps11635/data_sheet_c78-650053.html
Do anybody know if I can set up an anchor mobility group between the Flex 7500 and the WLC 5508?
Kind regards
Saravanan Lakshmanan
Yes, 5508 can be used as anchor controller for static anchoring while 7500 as foreign using central swtiching.
For Mobility:
Fault Tolerance
It is recommended to use Flex 7500 as both the primary and backup controllers.
Flex 7500 primary and backup controllers must be in the same mobility domain.
Ref:
http://www.cisco.com/en/US/products/ps11635/products_tech_note09186a0080b7f141.shtml
For Mobility:
Fault Tolerance
Ref:
Thank you very much Saravanan
