Cisco ISE + WLC NAC
felcor
Hello All,
I have a problem with a kind of method authentication.
I was configured Mac filtering and Open authentication in my SSID, but when I mark option in NAS State as Radius NAC and then Apply the WLC give me the information:
Request Failed - Radius NAC is available only for WLAN with 802.1X/WPA/WPA2 Layer 2 security.
So I need this configuration for sucess in authentication and I cant to do this.
Somebody could help me ?
"Radius NAC is available only for WLAN with 802.1X/WPA/WPA2 Layer 2 security."
What do you have on the WLAN Layer 2 security?
-If I helped you somehow, please, rate it as useful.-
Security is none (open)
Sandeep Choudhary
My WLC SW version: 8.0.152.0
I am using SSID with
1. Layer 2security as NONE, MAC filtering enabled.
2. AAA override enabled
3. NAC state is RADIUS NAC
and its working.
So change these setting on SSID and try again.
Dont forget to rate helpful posts
WLC SW version: 7.0
1. Layer 2security as NONE, MAC filtering enabled. (the same)
2. AAA override enabled (the same)
3. NAC state is RADIUS NAC (whem I choose this option and click Apply the message show me that not is possible to do this)
