09-15-2019 06:34 PM - edited 07-05-2021 11:00 AM
I have a single 3802i with CME 8.5.151. The wireless clients can ping their default gateway and any other wireless host. These same wireless clients cannot ping any non-wireless (aka wired) host on the same subnet. I've been looking through the configuration and nothing is obvious. What am I missing?
--Patrick
09-16-2019 01:20 AM - edited 09-16-2019 01:22 AM
did you enable(drop) P2P blocking on specific WLAN.
09-16-2019 09:18 AM - edited 09-16-2019 09:36 AM
I don't see peer-to-peer blocking as an option in 8.5.x. Isn't that in a later release? As I understand it, it is for wireless to wireless blocking. All of my wireless clients can reach any other wireless clients. I'm just having trouble reaching wired clients such as printers, servers, storage, etc.
Patrick
09-16-2019 10:14 PM - edited 09-16-2019 10:15 PM
There are three options:
Disabled—Disables peer-to-peer blocking and bridges traffic locally within the controller whenever possible. ...
Drop—Causes the controller to discard the packets.
Forward-UpStream—Causes the packets to be forwarded on the upstream VLAN.
you have to use CLI to configure it.
Can you try this comamnd and chekc again:
config wlan peer-blocking disable <wlan_id>
Rergards
Dont forget to rate helpful posts
09-17-2019 06:45 PM
I just tried that command. Here are the results.
Request failed - WLAN 1 is already in the requested state.
Any more ideas?
--Patrick
