Cisco Mobility Express Controller issue
sheikhrazib2766
I've downloaded and installed Cisco Mobility Express Software in Cisco Access Point 3820i. But after reboot, it doesn't broadcast SSID.
I've gone thru CLI configuration and configured the whole Controller but still it doesn't broadcast the SSID. I've factory reset the device. And still nothing.
Any advise would be much much appreciated.
Sandeep Choudhary
paste the sh version command output from AP console.
Dont forget to rate helpful posts
patoberli
The AP might not have enough power. Do you use a PoE+ power injector / switch?
The 2800 and 3800 require PoE+ to fully work. It works with PoE, but doesn't bring the radio interfaces up.
