610
Highlighted
Beginner
Cisco Mobility Express crash (AP 1832 reboot) upexpectly in 1-3 daysWe have 3 Cisco AP 1832 , we set one as ME ,other two are AP ,but we found these three will automatic reboot in 1- 3days,nearly 2day ,never less then 1 days,and never more than 3 days. I have tried several editions ,8.4,8.8,8.9 ,al
I have tried several editions ,8.4,8.8,8.9 ,all the same situation.
I have uploaded the crash file , please help me check and found the problem.Thanks.
Everyone's tags (1)
14 REPLIES 14
Beginner
Re: Cisco Mobility Express crash (AP 1832 reboot) upexpectly in 1-3 daysWe have 3 Cisco AP 1832 , we set one as ME ,other two are AP ,but we found these three will automatic reboot in 1- 3days,nearly 2day ,never less then 1 days,and never more than 3 days. I have tried several editions ,8.4,8.8,8.9
Additional information:we have tried to make another AP as ME , the problem still exist .
Beginner
Need Help ,Please
VIP Advocate
We (the community) can't troubleshoot the crash files, only TAC can do this.
I suggest you try 8.5.151.0 as a release, that should work stable.
Beginner
I don't have a service account ,so i can't submit a TAC .and i can't found Where to download 8.5.151 ,i only found 8.5.140
VIP Advocate
You should have a service account...
But 8.5.140.0 is also quite good and recommended.
Beginner
I have tried 8.5.140, it have the same problem
VIP Advocate
Ok, this is very untypical and might be because of a hardware fault. I suggest you open a TAC to troubleshoot the crash files.
Beginner
But it is impossible that 3 devises all have hardware issue .
VIP Advocate
It is very rare, but I've never seen so many APs crashing either.
You could try to reset one of them to factory defaults, only make the necessary configuration (LAN and SSIDs) and then observe if it remains stable.
Beginner
It is workable idea, it is very strange , I let AP03 start 30 minutes after other two Aps, then AP01 and AP02 reboot at the same time and 30 minutes later ,AP03 reboot .... It seems a scheduled reboot.... But in the crash file , it shows kernel crashed
AP AP-1832-01 crashed at Tue Jun 25 20:29:22 2019 UTC(BOOT_CNT 52) due to:
kernel panic
============ image version ============
Active version: 8.9.111.0
Backup version: 8.9.100.0
============ build.info ============
Tue Jun 4 07:27:45 PDT 2019
wnbu-bld-lnx11
/data/BUILD/workspace/89MR1_ME_CCO/corsica/router
* (no branch)
<0>[06/25/2019 23:00:58.4271] Kernel panic - not syncing: Fatal exception
<2>[06/25/2019 23:00:58.4271] CPU0: stopping
<4>[06/25/2019 23:00:58.4271] Backtrace:
<4>[06/25/2019 23:00:58.4271] [] (dump_backtrace+0x0/0x114) from [] (dump_stack+0x18/0x1c)
<4>[06/25/2019 23:00:58.4271] r6:c4092000 r5:c08a0adc r4:00000000 r3:c0881ecc
<4>[06/25/2019 23:00:58.4271] [] (dump_stack+0x0/0x1c) from [] (handle_IPI+0x10c/0x210)
<4>[06/25/2019 23:00:58.4271] [] (handle_IPI+0x0/0x210) from [] (gic_handle_irq+0xfc/0x108)
<4>[06/25/2019 23:00:58.4271] [] (gic_handle_irq+0x0/0x108) from [] (__irq_svc+0x40/0x50)
<4>[06/25/2019 23:00:58.4271] Exception stack(0xc4093d60 to 0xc4093da8)
<4>[06/25/2019 23:00:58.4271] 3d60: 00000000 00000000 73797379 00010000 c18e0300 eeebd180 c4092000 00000000
<4>[06/25/2019 23:00:58.4271] 3d80: eeebd2f4 c40f6080 eeebd180 c4093e3c 00000000 c4093da8 c0409568 c04097a4
<4>[06/25/2019 23:00:58.4271] 3da0: 60000013 ffffffff
<4>[06/25/2019 23:00:58.4271] [] (__schedule+0x0/0x638) from [] (schedule+0x6c/0x70)
<4>[06/25/2019 23:00:58.4271] [] (schedule+0x0/0x70) from [] (_ZN6Master9block_allEv+0x10c/0x124 [merakiclick])
<4>[06/25/2019 23:00:58.4271] SMP: failed to stop secondary CPUs
VIP Advocate
Yes very weird. If you have any management system that maybe tries to influence something, try to set a different SSH and SNMP password/community. That way you can stop external influence.
I found a crash bug in the software release you are using:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb70551
And another which might affect you or might not:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp77267
In any case this is something we here in the community can't really help, only TAC can do this.
VIP Advocate
Just today was the new software 8.8.125.0 released, which fixes two possible crash bugs.
You might want to try this specific release and see if it's better.
Beginner
Thanks. But i can not download it ,i don't have a service account .
VIP Advocate
Then I think it's time to get a SMARTNet for at least 1 AP, so you have software and TAC support.
Content for Community-Ad
August's Community Spotlight Awards
