Cisco Mobility Express with Controller 5500
I'm install in my network one new AP 1562b, but due IOS of the controller I dont can install in controller, I gonna configuration it how autonomos (Mobility Express) but in documentation talk that Mobility can't work with other Controller.
"You must not have other Cisco Wireless LAN Controllers; neither appliance nor virtual in the same network during set up or during daily operation of a Cisco Mobility Express network. The Mobility Express controller cannot interoperate or co-exist with other Wireless LAN Controllers in the same network."
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-5/b_cisco_mobility_express_8_5/b_cisco_mobility_express_8_5_chapter_01.pdf
I dont undestand, because the firmware is difference CAPWAP other Mobility Express.
Some problem if I include Cisco AP Moblity Express in network with one Controller 5500 series?
pieterh
this is about controller discovery within the same (V)LAN/network
because L2 broadcast is used, AP's might connect to the wrong controller.
I guess if you create a separate vlan for this AP and others that use this ME as controller, you can make it work within the vlan
if you use dhcp option 43 and/or dns-discovery  you need to configure this accordingly
6 Replies 6
pieterh
Hi pieterh
Thank you for answer.
So, I need only create one new VLAN. I can't user option 43 because the 3 APs of this model I gonna configuration how Master (100% autonomous), or I require to set up one how Master and others how slave?
you can make it work with a separate vlan
you can use dhcp option-43 but it needs to be different than your default
in the scope for this vlan/subnet is needs to point to your ME
for the others the lightweight image will be sufficient, but ME also has a HA-setup you may use
Hi  pieterh
AP with lightweight  can register in master ME?
yes ME works as if the ME-master has a controller integrated
Thank you my friend.
I believed that Mobility Express registerd only with Mobility Express.
