Cisco PoE+ AP with Antenna Power Requirements
UT_games
Hey everyone,
Question: Does an antenna require more power to the AP via PoE+?
Ultimate Question: I know that PoE+ will power the IW-6300 AP, but will PoE+ power the IW-6300 AP with the Air-ANT2566P4W-R Antenna?
Below is our current design.
">" means connected to
Cisco IE-3200 switch > IW-6300 AP > Air-ANT2566P4W-R Antenna
The Cisco IE-3200 supports PoE+
        - Estimated PoE+ output to the Powered device would be approx 25W
The IW-6300 has a PoE+ / UPOE auto sense inbound port
       - I can't find baseline power needed to run this AP. Looked through the datasheet
The Air-ANT2566P4W-R Antenna
       - I don't see in the datasheet anything about power required.
Thanks in advance!
yes, The listed AP power requirement including what power needs for those radio chains. The antenna itself does not require active power
Rasika
*** Pls rate all useful responses ***
10 Replies 10
It requires a specific power injector, if you need to power it via PoE. Refer page 40 of below document
https://www.cisco.com/c/en/us/td/docs/wireless/outdoor_industrial/iw6300/hardware/install/guide/b_iw6300_hig.pdf
The access point can be powered by one of these methods:
Power over Ethernet by power injector AIR-PWRINJ-60RGD1= and AIR-PWRINJ-60RGD2=
• AC or DC power
• IW-6300H-AC-x-K9: 85-264V~ maximum, marked 100-240V~, 50-60Hz, 1.3A
• IW-6300H-DC-x–K9: 44 to 57Vdc, 1.2A
• IW-6300H-DCW-x-K9: 10.8 to 36Vdc, 5.9A
Rasika
• AC or DC power
Rasika
Oh okay, so the injector increases the power to the AP to 60W? Is that correct?
Yes, that is correct. It provides 60W to AP
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/power/guide/air_pwrinj_60rgd.html
Rasika
Rasika
So this should be plenty of power to supply the AP and its antenna right?
Rasika
Rasika
Sorry for my ignorance....Is this what that installation would like that or are there other ways to install?
That's correct. AP powered from injector which is sit in between switch & AP
Rasika
Rasika
Forgive me if this is in the installation guide, but what the maximum cable lengths for the Ethernet cable between the switch to power adapter and the power adapter to AP?
With Ethernet it is 100m max. You should not go for that max limit (typically end to end 80-90m including patch leads if you want to stretch it)
Rasika
Sorry, I have a question. The AP cannot be powered by a poe+ switch?
In the following link (IW6300) mention this:
Powering the Access Point
Power over Ethernet
  • Power injector, AIR-PWRINJ-60RGD1= and AIR-PWRINJ-60RGD2=
  • Power over Ethernet Plus (PoE+) or Cisco Universal Power over Ethernet (UPOE) switch
AC or DC power
Thanks in advance.
Lucas M.
