04-28-2014 01:38 AM - edited 07-05-2021 12:44 AM
I can create an SSL cert and send it to a CA for signing and then combine the resultant cert with the root and import to the WLC to make sure that https browsing of the WLC doesn't throw up an cert errors.
Some might say this is cosmetic but I like it.
Anyway we have installed Prime but the process seems different.
I read through the cisco docs but cant seem to get my head around the process.
Can any one guide me, Janet and John style?
04-28-2014 07:17 AM
Which doc did you read? This one seems pretty straight forward
http://www.cisco.com/c/en/us/td/docs/wireless/prime_infrastructure/1-2/configuration/guide/pi_12_cg/csr.html#wp1042823
HTH,
Steve
04-28-2014 03:27 PM
Yes. That was the document I found fairly incomprehensible.
It seems as though I have to create the cert from within prime rather than use OpenSSL . Is that the case ?
04-29-2014 06:02 AM
That is correct. Do not use the root console at all, it's not needed for normal PI jobs. This way the certificate gets stored in all the right places.
04-29-2014 06:02 AM
[edit]
Deleted and added at the right place.
