09-22-2019 10:42 PM - edited 07-05-2021 11:02 AM
Hello experts,
I want to setup two Cisco prime in HA.
Primary server is installed and working. Yesterday i installed a new PI and concurred as secondary PI.
Only difference between these two is : Primary has a patch 2.0 and secondary dont.
Now while doing HA registration i am getting this error:
Error(s): You must correct the following error(s) before proceeding: Error: High Availability Registration cannot be done. Check whether the Primary and Secondary are running with different versions of the product.
i try to create a FTP user but is not working :
Error : This command cannot be executed on a server in secondary HA mode
Any idea why I am getting this and how can i insatlled the same patch on secondary PI?
Solved! Go to Solution.
09-22-2019 10:58 PM
did you try to installed the same patch on secondary PI ? if not then do it and tra again.
Dont foregt to rate helpful posts
09-23-2019 01:27 AM
Cisco recomand to update the patch via GUI.
did you alredy pair the servers or just installed new server as secondary (HA) ?
Dont forget to rate helpful posts
09-23-2019 02:50 AM - edited 09-23-2019 03:01 AM
1. If your secondary cisco prime is UP and running in HA then access it via: https://ServerIP:8082
2. It will ask for authenticaion key twice ..then Click the HM web page’s Software Update
3. Upload the .ubf file and install it.
09-22-2019 10:58 PM
09-23-2019 12:12 AM
Yes i tried but installation not working.
% Unable to unbundle the package. Package may be corrupt or there is not enough disk space
thanks
09-23-2019 01:27 AM
09-23-2019 01:33 AM
Active(Primary) is running form long time.
Secondary : I installed it new last week to pair with Primary.
How to do it via GUI ? Can you please help.
09-23-2019 03:02 AM
Thank you.
