Highlighted
Cisco Virtual Wireless Controller
I need to know how the physical connection to cisco Virtual Controller vWLC will be, because I need to know about the reduction.
Example of the image below the reduction and physical connection between 3504/5520/8500 controllers.
I put an image attached.
How will vWLC look like this?
2 REPLIES 2
Highlighted
Hall of Fame Master
The vWLC doesn’t support SSO only N+1. The image you have provided is for SSO and only supported on the appliance that is mentioned.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-4/config-guide/b_cg84/high_availability.html#vwlc-and-nplus1-ha
-Scott
Highlighted
VIP Mentor
Its not for vWLC.
you nee dto download this image:https://software.cisco.com/download/home/284464214/type/280926587/release/8.10.130.0
and setup it as N+1.
deployment guide:  https://ccieroot.com/2016/02/20/installation-of-virtual-wireless-controller-vwlc/
Dont forget to rate helpful posts
Content for Community-Ad
