Cisco WCS reports not working
Srin_G
Level 3
Level 3
Hi guys,
It used to work before but now when i run a report it comes up with strange error. I have attached the screenshot. Any suggestions or help is appreciated.
cheers
Srini
Here is a link
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
-Scott
9 Replies 9
Scott Fella
You have issues with any other reports or just that one? What version of WCS are you running.
-Scott
i tried 4 and all have the same issues. we run version 7.0.172.0 for WCS and the controllers version is 7.2.103.0.
thanks mate.
cheers
That's why... Your WCS/NCS has to the same version or a higher version than the WLC.
Rule of thumb..... WCS/NCS/MSE code >= WLC Code
-Scott
ok mate, i will upgrade and will get back to you.
cheers
The issue is that you need to migrate to NCS. WCS doesn't support WLC code 7.2.x.
-Scott
i thought so thanks mate.
just consulted with my colleagues can we upgrade this version? or we need to get cisco prime?
cheers
Here is a link
-Scott
You need Cisco NCS Prime. Get the migration since its only $2000.00 on special. I think it's still that price.
-Scott
