Cisco Wireless and Apple TV
dpatkins
Good day,
We are trying to set up Apple TV on our 802.1x SSID.  So far, we have input authentication as well as loaded two certificates from our Cisco ACS.  I believe this did not need to be done.
Is there a way we can configure APPLE TV on our wireless network?  And is there a Guide that I can follow to get this done?  I have seen many documents but I have not seen that one that says, "do it this way, it works".
Thank you
Dwane
Stephen Rodriguez
Honestly, I would go with a PSK vs .1x for the Apple TV.  I don't think the A-TV supports .1x in a user friendley format.
I have mine setup as PSK and it joins and I can stream to it just fine.  The one thing to be aware of, is how the A-TV works WRT multicast especially if you are using different VLANs
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
5 Replies 5
Jeff Van Houten
Level 5
Level 5
What wlc are you using? The real low end wlcs don't support multicast the way apple needs it.
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Hi Dwane,
This is how I did this in my environment with WLC 7.4.x code.
http://mrncciew.com/2013/03/27/configuring-mdns-on-wlc-7-4/
As steve pointed, it did not support WPA2/AES Enterprise (at least sometime back) & I used a wired connectivity to Apple TV, since my user wirless is 802.1x. This worked fine even they (Apple TV & clients) are sitting on different vlan
This is the latest (7.5.x) Apple TV deployment guide in case if you are on this code.
http://www.cisco.com/en/US/docs/wireless/technology/bonjour/7.5/Bonjour_Gateway_Phase-2_WLC_software_release_7.5.html
Rasika
**** Pls rate all useful responses ****
George Stefanick
I've configure Apple TV with 802.1X, we use PEAP. Works fine with no issues. On the Apple TV you need to load the cert root and intermediate for who ever signed your cert on the radius server. In our case it was entrust. To see if it working, just check your Apple TV network settings make sure you have an IP address. Also you can quickly tell by seeing if the apple tv has the menu items up ..
Thank you all for your quick response.  We went entirely with a seperate SSID with WPA2/PSK.  It was a quick set up and works good.
Have a great day.
