Cisco WLC 2504 sofware update
umar bhatti
Dear Friends,
I am using Cisco WLC 2504 current software version is 7.0.220.0 and I want to upgrade it to the latest version which is 8.x.x.x.
Could you please help and advice the best way of doing it? Also can I upgrade direct to the latest version or do I have to upgrade step by step?
Thank you very much for your help and support.
Umar
Yes, you can go directly to 8.0.x from 7.0.x code. Refer below link
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80mr1.html#68333
Make sure you refer the release notes for any known issues with this code. Also upgrade FUS to 1.9.0.0 as well. This will take around 30 min downtime as well.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.html
If you have different AP models, MSE, Prime products, refer this compatibility matrix as reference.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Rasika
**** Pls rate all useful responses ****
Rasika
Hi Rsika,
Thank you very much for your reply. I’ll go through the documents and let you know if I need further help probably I do :).
Umar
Hi Rasika,
I have followed your instructions and successfully upgraded the software and FUS.
Thank you very much for your help.
Kind Regards
Umar
Good to hear that & glad I was able to help you..
Rasika
