02-05-2019 07:10 AM - edited 07-05-2021 09:48 AM
I have a Cisco WLC 5520 on my network. From the documentation, the WLC can support up to 100 FlexConnect groups but I can only create 15 on mine.
Has anyone experienced this and is there a way this can be changed?
Solved! Go to Solution.
02-05-2019 03:09 PM
From the release notes the 5520 can support 1500 Flexconnect groups with 100 APs in each.
Do you get an error when you try and create Flexconnect group number 16?
Have you tried creating via the CLI as sometimes the CLI give better error notifications:
config flexconnect group <Group name> add
Also what version of code are you running
02-05-2019 07:53 AM
02-06-2019 12:20 AM
My software version is 8.5.140
@M. Wisely wrote:
I've just tried this on one of our 5520s running 8.2.170.0 and I'm not limited to 15. What version of code are you running?
02-05-2019 03:09 PM
02-06-2019 12:31 AM
02-05-2019 03:29 PM
Hi @vezeh
are u sure you´re having an issue creating the flexconnect group or you can not broadcast WLAN with ID below of 16?
Be sure that your WLAN ID is greater than 16, can u plase share the error?
Thanks.
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
02-06-2019 12:43 AM
