11-14-2019 05:14 AM - edited 07-05-2021 11:18 AM
I got WLC 5520 and around 1000 APs connected to it in local mode.
VLAN 1021 - AP Management
VLAN 100 - Guest Internet Access
VLAN 200 - Telephones
On all switches I have added VLAN100, VLAN1021, and VLAN200.
Ports where I got AP-s are access 1021.
Do I really need to have all other VLAN's added to each switch?
How does traffic tagging works, are they tagged on AP, or WLC?
If I have e.g. VLAN 300 trunk with WLC, but I do not have VLAN300 on each switch... will traffic that connects to SSID for VLAN300 be in VLAN 300 normal?
11-14-2019 05:34 AM
No
There is no tagging since the traffic is handled by the CAPWAP protocol.
Actually the question is 'misty' , traffic will be forwarded to vlan300 by the controller, the rest depends on the design of the Intanet network.
M.
11-14-2019 06:52 AM
11-14-2019 10:14 AM
11-15-2019 01:13 PM
So do I need to have VLAN 200 for telephones on all my switches where I got APs?
Or is it enough to have it only on controller?
If that is correct, basically I only need to have 1021, which works as tunnel to controller and good to go?
11-15-2019 03:41 PM
