09-23-2013 01:30 PM - edited 07-04-2021 12:54 AM
I am working on a client network where we will be installing around 180 WLCs. I have already installed 15 WLCs. All these WLCs were added to Cisco Prime Infrastructure 1.3 and synced their config.
Most of the configuration on these WLCs remain same.
I was wondering, is there a way to create a CLI command template from the Cisco WLCs which are already deployed and use this CLI template on Cisco Prime?
Is there a way via which I can capture all the Commands that were configured on the WLC CLI?
CJ
09-23-2013 01:37 PM
Here is the link to all CLI command reference for 5508
http://www.cisco.com/en/US/customer/products/ps10315/prod_command_reference_list.html
Rasika
***** pls rate all useful responses *****
09-23-2013 01:38 PM
You can go in and discover the templates from the WLC.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
09-23-2013 01:52 PM
Hi Rasika,
Thanks for quick response. I did go through the CLI Command reference Guide and I have created a template, upto some extent. Even though its a time consuming process, I can create complete template.
But, I was curious, whether Cisco Prime or WLC has any CLI or GUI option to show all the configuration that has been done on the Controller (All CLI Commands)?
My idea here is to make the WLC deployment process automated with minimal intervention/changes.
I've created the below CLI template on Cisco Prime and push it to the new WLCs as and when they will be added to Prime.
CJ
09-23-2013 03:56 PM
Hi CJ,
I believe you want to have standard configuration across your controllers. You should have very basic configuration via initial script & then download a template configuration on to it would be the easiest way.
For a template configuration, if you take a backup of currently configured controller & then grouping the configuration (like interface, wlan, acl, band specific) it would be easy to understand.You should have documented framework for the consistent WLAN IDs, AP group names, Interface groups, features you want to enable.
Only few parameters you need to change when configuring a particular site WLC. few of them are
1. Interface IP address
2. Mobility configuration
3. System name
Rasika
09-23-2013 01:52 PM
Why not just backup the configuration from a WLC that is configured and then edit it and upload (restore) it to the the other WLC. That would be the easiest way:)
09-23-2013 02:00 PM
Hi Scott,
Thanks for the reply and I used to follow the same process which you explained.
I want to see/explore possible options to perform this. I was thinking it will be easier and quicker for the customer to use the CLI Templates rather than editing the backup WLC Configs.
In this way, I can just create a document and highlight the exact locations where changes need to be made on the CLI command list.
Just my taught process.
CJ
09-23-2013 02:08 PM
Then it's best for your to create a template using excel or something else. I created one for our company that generates configurations and makes it configuring multiple wlc's easy. You can do a show run-config commands, but the commands are not in a specific order to be pushed so you will need to tweak that piece.
09-23-2013 02:22 PM
Hi Scott,
Is it a normal Excel sheet, where you include all CLI Commands or are you running a script?
If possible, can you please share a sample template as how to create a script.
CJ
09-24-2013 01:53 PM
You can refer to the link -
http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0temp.html#wp1337951
09-24-2013 05:19 PM
Cisco Prime Infrastructure provides AutoInstall capabilities for controllers. A Cisco Prime Infrastructure administrator can create a filter that includes the host name, the MAC address, or the serial number of the controller and associate a group of templates (a configuration group) to this filter rule. The Prime Infrastructure pushes the initial configuration to the controller when the controller boots up initially. After the controller is discovered, the Prime Infrastructure pushes the templates that are defined in the configuration group. For more information about the AutoInstall feature and Cisco Prime Infrastructure, see the Cisco Prime Infrastructure documentation.
Please refer the link below:-
