Cisco WLC - Creating Disclaimer Page
Hi Cisco TAC
I've a Cisco WLC 2504, and have created an SSID for guest purposes. Is it possible to skip the guest user authentication and display only the disclaimer page, with the PROCEED button? If yes, what are the steps to accomplish this task? If you've a Cisco guide, that will be great
Thank you.
Warm regards,
Ramraj Sivagnanam Sivajanam
WiFi Trainers
Hi Ramraj,
Web-passthrough does not ask for credentials and instead gives a warning/disclaimer page. This should meet your requirements. Please find the below link which gives more information about web passthrough and also how to configure it.
Best Regards,
www.wifitrainers.com
Learn from the Best To be the Best!
Change the way you look at wireless client connectivity forever by registering to watch this free webinar and also stand a chance to win our Wireless starter kit worth $8000 for free!!
Hi Wifi Trainer
I don't see the URL link in your reply. Please kindly advice.
Warm regards,
Hi Ramraj,
Sorry about that :).
Please find the link below:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/115951-web-auth-wlc-guide-00.html#anc13
This also has a link for a config example on configuring webpassthrough.
Best Regards,
