297
Beginner
Cisco WLC LAG
Hello all
we have CIsc 5520 in LAG mode on the controller - does it need port-channelling on the switch end? it goes to two different switches but the switches are in VSS mode (Cisco6800)
Everyone's tags (1)
13 REPLIES 13
VIP Advisor
Re: Cisco WLC LAG
yes for high availability user port-channel, use different physical switch port in each physical switch (when VSS switch over occurs) you still have access.
BB
*** Rate All Helpful Responses ***
VIP Advisor
Re: Cisco WLC LAG
 Actually, Port-channel is not required. Port-channel is a feature if you, eventually,  needs more throughput in a given uplink. Instead 1 Giga or 10 Giga you can bound multiple interfaces and rise this number to up to  8 Giga or 80 Giga.
 What is required on this case it interface in trunk mode so that you can split your traffic accordingly based on Vlans.
-If I helped you somehow, please, rate it as useful.-
Beginner
Re: Cisco WLC LAG
Thanks both
in the past i dont remember port-channeling so is this required or not?
no concern about bandwidth but just not sure if this is needed or not? because we see laptops flapping on logs on the core switch between one access point another?
VIP Advisor
Re: Cisco WLC LAG
As I said, port-channel is required only if you need more bandwidth. What is required for your scenario is trunk mode on the interface and/or port-channel.
Beginner
Re: Cisco WLC LAG
we are seeing flapping messages
28275320: Sep 9 17:21:28.132 GMT: %MAC_MOVE-SW1-4-NOTIF: Host d4e2.8011.af59  in vlan 10 is flapping between port Te1/1/17 and port Te2/1/17
28275356: Sep 9 17:26:40.374 GMT: %MAC_MOVE-SW1-4-NOTIF: Host d4e2.8011.af59 in vlan 10 is flapping between port Te1/1/17 and port Te2/1/17
Te1/1/17 is connected to WLC port 1 and Te2/1/17 is connected to WLC port 2 and in LAG mode
so does this need port-channeling in core switch? hence the question
VIP Advisor
Re: Cisco WLC LAG
We see the messages are normal as per my experience. until you see any issue here ?
BB
Beginner
Re: Cisco WLC LAG
Thanks but why would these messages appear?  if i port channel will these messages go away?
VIP Mentor
Re: Cisco WLC LAG
"we have CIsc 5520 in LAG mode on the controller "
If you have LAG on WLC, then it is mandatory to use port channel config on your switch. Then those messages will go away
Rasika
*** Pls rate all useful responses ***
VIP Advisor
Re: Cisco WLC LAG
@Rasika Nayanajith
just want to know is the same case with 8K controllers ? can you point me, i do see that messages, when the client roaming ..not found that tip before. like to explore me to fix that.
BB
VIP Mentor
Re: Cisco WLC LAG
when you enable LAG on a WLC (any hardware model) & two ports of WLC connect to two different switchports (on a VSS pair or switch stack), you should bundle those ports into a port channel group at the switch end.
Those mac flapping messages should not be occur in that situation
Rasika
VIP Advisor
Re: Cisco WLC LAG
yes the ports are bundled, and we can see its bundled on switch side.
do we see any other config required on WLC side, as you mentioning on this post...
we see mac flapping while client roam doing.
BB
Beginner
Re: Cisco WLC LAG
Thank you all
Enabling LAG helped mac flapping from one interface to another however we do see mac address notification on switch when client roams from AP to AP which is normal i guess
just which level of notification on switch logging will make these messages dissappear?
Highlighted
VIP Advisor
Re: Cisco WLC LAG
yes that is normal that what we see when we configured WLC 8K
glad it hel, and can we can make it as resoved.
BB
Content for Community-Ad
August's Community Spotlight Awards
