10-15-2015 01:30 AM - edited 07-05-2021 04:05 AM
If you issue the show port summary command on a Cisco Wireless Lan Controller
show port sum
STP Admin Physical Physical Link Link
Pr Type Stat Mode Mode Status Status Trap POE
1 Normal Disa Enable Auto Auto Down Enable N/A
2 Normal Disa Enable Auto Auto Down Enable N/A
is this output applicable to the Management interface or the network interfaces of the device? cant quite figure it out and cannot get this interface to come up
thank you
10-15-2015 04:05 AM
Management interface is a logical interface (think VLAN). Ports are physical interface. Notice the Link Status shows "DOWN".
10-16-2015 04:11 PM
What WLC model is this ? 44xx ?
Make sure you connect these port to 1Gbps switchports
