02-23-2012 10:33 AM - edited 07-03-2021 09:38 PM
Hello All,
I have 10 Ap´s in a building under a WLC5508 with CleanAir activated, however when the users, turn on a MW oven, the clients located near, lost completely their connections.
I have activated the EDRRM, but the interference is in all channels, therefore the loss of signal keep it.
Someone could tell me if this is normal or I have do any adjustment on the config of Clean Air?
Thanks in advance!
02-23-2012 02:54 PM
What kind/model of WAP? CleanAir is the exclusive domain of the 3500 and 3600 WAP.
02-23-2012 03:13 PM
Hello Leolaohoo,
I´m sorry, i forgot write the WAP model, effectively the AP´s are models
AIR-CAP3501E-A-K9
02-23-2012 03:20 PM
Go to Wireless > 802.11b/g/n > CleanAir
02-23-2012 03:40 PM
OK, I´m there
I attach the image file from WLC
02-23-2012 04:21 PM
Ok, so CleanAir is enabled. To verify, go to Monitor > Cisco CleanAir > 802.11b/g/n > Interference Devices
Alternatively, you can choose Air Quality Report or Worst Air-Quality Report.
02-23-2012 04:23 PM
The client's lost their connection because CleanAir WORKED. The WAPs changed channels but it is up to the clients to find the NEW channel the WAP is broadcasting on.
Generate the report and find out what channel the microwave oven is doing "business". If it's the entire channel then I'd consider getting a new model of microwave oven.
02-23-2012 05:23 PM
Ok, let me check the air report and I will propose to the end customer another MW oven.
02-23-2012 06:45 PM
I think I'm in the wrong profession. Maybe I ought to be a microwave oven salesman.
02-24-2012 08:21 AM
Jajajajajaja, that´s right!
Thanks so much for your feedback.
02-24-2012 12:42 PM
Hey Leo,
Forget Microwave ovens, you should work for these guys +5
Cheers!
Huff
02-24-2012 02:56 PM
Thanks "Smooth" Rob.
BTW: Has anyone heard from Maria lately?
