10-08-2012 12:26 PM - edited 07-03-2021 10:47 PM
Hello
Do I need to buy additional license for clean air to work, currently my BOQ cover
Also I would like to understand are there any better model than AP 3502 & newer WLC model than 5508 ( I would have application users accessing application via Wireless LAN )
thanks
ST
10-08-2012 12:28 PM
No license required. Just depends on the AP's that you already know.
10-08-2012 12:30 PM
Here is a deployment guide for CleanAir
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns742/ns982/c07-610746-01_cleanAir_guide.pdf
10-08-2012 12:40 PM
Thank you Scott for the guide will have a look at that.
5500 series WLC got 8SFP uplinks hence;-
thanks
ST
10-08-2012 12:44 PM
Well for one, you either use LAG or you don't. If you don't then it's up to you how you want to use the primary port and backup port.
If you want to broadcast specific SSID's on certain APs then you need to use AP Groups.
