CleanAir operational status is DOWN
Dhikra Marghli
Level 5
Level 5
Hi Guys,
Quick question.
accces point 1815i
Vcontroller cisco
I'm enabling CleanAir on my AP's, but the CleanAir operational status is DOWN. Why is it down when I've enabled CleanAir?
i send a screen : picture about this problem ??
i
Sandeep Choudhary
As fasr as i know, 1815 AP dont support cleanair.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-4/b_AP_1815_wall_plate_deployment_guide.html
Q: Does the AIR-AP1815W support CleanAir?
A: AIR-AP1815W does not support CleanAir.
Dont forget to rate helpful posts
Sandeep Choudhary
IF  CleanAir/SI Oper Status===> NA  ===> means ?? instead Down
and
CleanAir/SI Admin Status ==========>  NA menas ?? instead  Disable
thanks in advance
