Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
454
Highlighted
Beginner
Client access to AP1552
Hi ,
We have just finished installation of 12 AP 1552 as access points , clients are 7925G phone , after installation and configuration all clients can register and access to AP's in wireless environment but in IP we can't access to phones from our servers ,
For your information all phones and AP's and Ct5508 Controller are same subnet .
We need install and configuer all 1552 just as Access points in 2.4Ghz , we don't need any mesh configuration .
As for test we tried to connect to network by Laptop PC , it connected to access points but no network .
I apprecited your help and let me know how to configure Controller and AP's .
Thank you
Everyone's tags (2)
5 REPLIES 5
Highlighted
Hall of Fame Master
Re: Client access to AP1552
Sounds like a configuration issue. First off, you need to explain how everything is setup. Are all the mesh AP's connected to the network either with fiber or copper? They are all joined to the WLC and are setup in bridge RAP mode? Switch ports are configured as a trunk or access?
-Scott
Highlighted
Beginner
Hi ,
Thanks for your reply ,
1- All AP's connected to network vis Cisco 2960G Cooper port.
2-All AP's joind to WLC and we set static IP address to all  of them . ( WLC Firmware version : Air-ct5500-k9-7-2-103-0 but are going to upgrade it to AIR-CT5500-K9-7-2-111-3 )
3- There is no vlan configured so they are in same vlan and 2960 switch port is in access mode and untagged )
4- We didn't set all AP to RAP but for test we set one ap as RAP and in client satus report in main page we checked 3 phone connected to this AP .
5- We can ping ALL AP's in entire network fo  example form 2960G and  CT5508 and even from 2811 Router that CME installed
Regards.
Highlighted
whats the current AP mode, set it to local if not already.
get debug client output for test pc.
Highlighted
Beginner
Problem Solved .
I Disabled DHCP Assignmet required in Security Tab of WLAN and every thing goes well .
Thank you
Highlighted
looks like you have static ip for the wireless client/phones.
Content for Community-Ad
Cisco COVID-19 Survey
