09-27-2018 02:34 AM - edited 07-05-2021 09:14 AM
Hi wireless expert:
These days,i have a problem that is all clients cannot associate to 5G wifi,only 2.4G OK.There are wlc and AP module as below:
WLC: 2504 ; software version:8.2.121.5
AP: AP1852
i have run "debug client xx.xx.xx.xx.xx.xx" command to try get the associate info.but unfortunately,there is no any info display.
other info:5G channel don't have interference,and channel utilization is so low.
So i don't know what reason about this problem,i guess the ap drop all traffic of 5G ,Can you tell me the probably reason?
09-27-2018 02:40 AM - edited 09-27-2018 02:47 AM
is 5Ghz Radio is enabled ?
is SSID visible ?
how did you configre dthe ssid ...with WPA2/aes or wpa/tkip ?
Dont forget to rate helpful posts
09-27-2018 02:49 AM
09-27-2018 02:54 AM
disable 802.11b/g/n (2.4 Ghz) on the wlan and try to connect a clinet to ssid with 5Ghz only...and see the logs in WLC.
If possible paste here as well to analyze the root cause.....
09-27-2018 03:00 AM
i have disabled 2.4g,just only have 5g.And client cannot associate to 5g ssid.the logging don’t have useful info,and debug client mac-address have no output....
so,i guess ap drop all traffic of 5g
09-27-2018 03:43 AM
09-28-2018 08:13 AM
09-28-2018 08:34 PM - edited 09-28-2018 08:38 PM
Could be CSCus83638.
Is there a reason why the controller/AP is running an old Engineering release image? Is it possible to upgrade the firmware of the controller?
09-28-2018 08:47 PM
09-28-2018 09:04 PM
@Rps-Cheers wrote:
i will test the workaround
See if it's possible to upgrade the firmware of the controller to, say, the latest 8.5.
09-28-2018 09:06 PM
12-13-2018 07:34 PM
Same thing. 8.2.164.0 and 3700's - just wasn't making any sense. Restarted 2 of the AP's and now they respond and will associate; although I gather this may be a temporary fix. Problem is - how do you even FIND which AP's are in this state ? I just hit the ones that really should have had connections and hadn't, but this is pretty tedious.
