Client roaming issue between APs
Dear Folks,
I have been facing an wireless Roaming Issue in our cisco Mobility express wireless controller. We used to Connect SSID (ISAP1) with Ipad's and will roam inside & Outside the Office. However, it seems to be the IPAD device is not getting connected automatically even it's very near to the access point.
When I turnoff and turn on the wireless settings, then it's getting connected. And It happens always.
As per the troubleshoot, I have upgraded the controller image. also enable the 2.5 & 5 Ghz band for this specific SSID. But the still the issue is same.
how can i sort out this issue. Can anyone advice
Client roaming decision is purely made by the client. See below specific to iOS device
https://support.apple.com/en-au/HT203068
In your case where client does not trigger roaming, it could be due to different reasons. primarily conditions does not meet to trigger roaming decision. Could be your client hear both AP strongly and no reason for it to roam to next AP even you are next to 2nd AP.
I would check power levels (show advanced 802.11a summary for WLC CLI) & see if clients RSSI to see if that falls on those roaming conditions of apple client
Rasika
*** Pls rate all useful responses ***
See also:
https://support.apple.com/en-us/HT207308
https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/technotes/8-6/Enterprise_Best_Practices_for_iOS_devices_and_Mac_computers_on_Cisco_Wireless_LAN.pdf
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2018/pdf/BRKEWN-2670.pdf
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-6/b_Cisco_Wireless_LAN_Controller_Configuration_Best_Practices.html?dtid=osscdc000283#concept_25B094B30CC84B65B817D5A19DE86D28
You don't mention what version you're using but it goes without saying that it should be up to date to avoid known bugs.
