Client session length on the WLC
Salman Naqvi
Folks,
In a Aironet based Network, how can we set the maximum length of session length on the WLC based on the MAC address of the Client.
Sandeep Choudhary
what is authentication you are using on WLAN ? Layer3 /webauth ?
If yes thens et these timesrs:
clinet user idel timeout: 300
Session timeout: Uncheck it(Disable)
Sleeping client: enable it and set it to 720Min
Dont forget to arte helpful posts
Authentication is Open, its not the WLC thats doing the security, there is a separate Radius server for that..
The question that I asked was to find a timer on the WLC for user sessions where user can be identified based on its MAC address.
Salman
craig.beck
Session timeout for clients is set in the Advanced tab of the WLAN.
