Cisco Community Designated VIP Class of 2020
251
Highlighted
Beginner
Client Throughput of common Devices
Hello guys,
i have to plan an High Density Deployment. For that it would be very usefull if there is any chart were are the Throughputs of common Wireless Devices such as IPADs, IPHONEs, Android Devices and common Laptops are listed.
Has anyone found a list like that at Cisco or somewhere ??
Really thanks for useful informations.
Kind reagards
Philip
5 REPLIES 5
Frequent Contributor
Hi Philip,
Aren't these numbers in direct sequence first of all with the 802.11 standard used and then how close are these to the AP?
I am curious what our colleagues will post here.
VIP Mentor
Re: Client Throughput of common Devices
I would use iPerf application ( available for all those type of devices) and measure the throughput with internal server.
Since all depend on RSSI/SNR , you hv to do this at your environment. Do it for a best case scenario ( single client connect to AP) and normal scenario. That will give you a good reference for your wireless performance.
Look at these devices tech spec( # special stream, frequency, channel width) with deployed wireless standard will help you to calculate theocratical throughput you should get
Rasika
***pls rate all useful responses***
Beginner
Hey guys,
@Florin
Yeah but the theoretical Throughput of an 802.11n Device is really depending on the available MIMO Technologie right ?
@ Rasika:
For sure i can do it on this way. My intention was that there is a table which already exist like for Example:
Ipad Gen 1.  1x1:1  a/b/g/n  Maximal Throughput 65 Mbps
Galaxy S4 ........
Are there any good Values which i can calculate in a High Density Scenario where i don´t know the clients e.g. in a Hotel Meeting Area ?
May my questions sounds a little bit unprofessional, thats why i have less expirience in High Density Deployments
Kind regards
Philip
VIP Mentor
Hi Phillip,
I am doing a trial with 802.11ac & working on performance testing with few available devices. I would think it may be useful to you as well. It is not fill with all the information, but I think you can develop a similar one that suits you in terms of different type of devices you are interested.
here is the my doc looks like
Here is different AP models 802.11n specs/data rates. That may be useful to you as well.
Rasika
**** Pls rate all useful responses ****
Hall of Fame Master
I don't think you will find this info anywhere. You will only find various test results from people who might publish their results.
-Scott
Content for Community-Ad
August's Community Spotlight Awards
