06-01-2016 06:11 AM - edited 07-05-2021 05:09 AM
hi,
we just finished implementation for one of our clients. everything is OK but with new Code there is a homepage and there are some information related to top using ap and top clients and so on..
now my client is complaining that he can see the details like Client username or client PC or smart device name only with the SSID which autherntication is 802.1x there are 2 more SSIDs wherer their authentication is WPA2-PSK, for those PSK cleints their device name or such infromation is not listed at home page.
so please suggest is there are a way to fix this ..
please find attached snapshot
re,
Anvar
Solved! Go to Solution.
06-01-2016 09:09 PM
Check local client profiling (DHCP & HTTP) is enabled on WLAN advanced tab
WLAN > Advanced > Local Client Profiling
Rasika
*** Pls rate all useful responses **
06-01-2016 09:09 PM
Rasika
06-02-2016 04:00 AM
Many Thanks Rasika,
hats off you guru.....
it worked ....
06-02-2016 01:57 PM
Glad to hear this Anvar.
06-02-2016 02:17 PM
What version code has a "homepage" with such a small client table.. mine is 132 chr wide (8.0.120.0). In anycase all my "usernames" are unknown. DNS is provided by an external server. and yes DHCP&HTTP are checked in local client profiling.
The only exception being those users logging to the web authenticated guest net.
06-02-2016 02:58 PM
David,
I think the code version you are looking for is 8.0.130.0
If you are using pre-shared keys the username will not appear. 802.1x or Web auth should display the users names.
I hope this helps
David
06-02-2016 04:40 PM
This is from dashboard view available from 8.1.x onward for 5508. This was available for 2504 since 8.0.x as well. See below
Rasika
