Config air-lap1041n-e-k9 with cisco 5500 (5508) series wireless controller. how to?
aricardor
Hi!
I try to configure a Cisco 5508 Wireless controller and 25 Air-lap1041 to use as VoIP and data. I read documents, manuals, etc, but the AP doesn't charge the configuration, or not conect with the Wireless Controller, why? No Radius server present, only WPA security.howto, please...
I try to put a static ip in the LAP, with lwapp or capwap command, (LWAPP/CAPWAP ap ip address direccion mascara) and the AP returns "You should configure Domain and Name Server from controller CLI/GUI." and i can't change the name of the AP (Command is disabled).
Log from AP:
using ÿÿÿÿ ddr static values from serial eeprom
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x83000800, 0xc0000000
RQDC, RFDC : 0x80000037, 0x00000184
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is NOT up.
PCIE1 port 1 not initialize
PCIEx: initialization done
flashfs[0]: 6 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 2369024
flashfs[0]: Bytes available: 30016000
flashfs[0]: flashfs fsck took 21 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 44:2b:03:dc:09:25
Ethernet speed is 1000 Mb - FULL duplex
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...###########################
File "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" uncompressed and installed, entr
y point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1040 Software (C1140-RCVK9W8-M), Version 12.4(23c)JA, RELEA
SE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 12:53 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 6 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 2369024
flashfs[1]: Bytes available: 29757952
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1041N-E-K9    (PowerPC405ex) processor (revision B0) with 98294K/32
768K bytes of memory.
Processor board ID FCZ1611W414
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 7.0.94.21
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 44:2B:03:DC:09:25
Part Number                          : 73-14034-04
PCA Assembly Number                  : 800-34273-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16075VZ3
Top Assembly Part Number             : 800-34284-03
Top Assembly Serial Number           : FCZ1611W414
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1041N-E-K9
% Please define a domain-name first.
Press RETURN to get started!
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:00:09.574: *** CRASH_LOG = YES
Base Ethernet MAC address: 44:2B:03:DC:09:25
*Mar  1 00:00:09.838: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log
(contains, 1024 messages)
*Mar  1 00:00:11.848: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar  1 00:00:11.892: %SYS-5-RESTART: System restarted --
SE SOFTWARE (fc3)
*Mar  1 00:08:16.954: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to up
logging facility kern
% Invalid input detected at '^' marker.
*Mar  1 00:08:28.047: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROL
LER
*Mar  1 00:08:28.049: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:09:08.282: %CDP_PD-2-POWER_LOW: All radios disabled - LOW_POWER_CLASS
IC_NO_INJECTOR_CONFIGURED AIR-CT5508-K9 (c464.138f.9345)
*Mar  1 00:09:08.282:  -Verify the required power-injector is installed on this
port: AIR-CT5508-K9(Gig 0/0/2).
*Mar  1 00:09:08.282:  -If a power-injector is installed, issue the command:"pow
er inline negotiation injector installed"
*Mar  1 00:12:19.976: %CAPWAP-5-STATIC_TO_DHCP_IP: Could not discover WLC using
static IP. Forcing AP to use DHCP.
*Mar  1 00:12:29.993: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:12:39.994: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:12:49.993: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:12:59.994: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:13:09.993: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
Not in Bound state.
*Mar  1 00:13:19.993: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does
not have an Ip !!
*Mar  1 00:13:19.993: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP
. Renewing DHCP IP.
logs from wireless controller:
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Gu
est
ap-manager                       2    untagged 209.165.200.231 Dynamic Yes    No
management                       1    untagged 209.165.200.230 Static  Yes    No
service-port                     N/A  N/A      192.168.1.157   Static  No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
i conect with service-port ok  and the management port works, i think.
AP442b.03dc.0925>ping 209.165.200.230
Sending 5, 100-byte ICMP Echos to 209.165.200.230, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
AP442b.03dc.0925>
Help, please!
i write in spanish:
Hola:
Tengo que configurar un cisco 5508 wireless controller con 25 air-lap1041n, para usarlo como acceso de datos y voz. ¿Cómo lo hago? He leído manuales, y seguido las instrucciones, pero el punto de acceso parace que no es capaz de cargar el perfil. No hay servidor radius, solo la configuración de una clave wpa. Alguién me puede indicar pasos, Gracias
Scott Fella
Please make sure your time is set correctly on the wlc. Also make sure you set the country domain on the wlc that matches your AP. I would then place the ap on the same subnet as your management up address of your 5508. Why did you create an ap manager on the 5508. You should set the management to be the dynamic ap manager so you only need one up address. If the ap and wlc is on the same subnet, the ap will join the wlc. Then you can move the ap to another subnet after it joins.
-Scott
13 Replies 13
Scott Fella
-Scott
Hi;
thank you so much.
The time and the country domain is set correctly on the wlc, but not on AP, how do i do? .  I delete the ap-manager, but i have a lot of dudes. The service-port ip address and the managament ip address could be at different nets? How can the ap to access the internet?   thanks
Hola:
lo primero, gracias.
El tiempo y la zona de pais (ES) está correctas en el WLC, pero en el AP no, ¿cómo se hace? He borrado la interfaz ap-manager, pero tengo una serie de dudas: ¿La dirección IP del puerto de servicio y la dirección de la management pueden ser de distintas redes? ¿Cómo es capaz el punto de acceso de acceder a la internet? Gracias
All traffic tunnels back to the wlc if the APs are in local mode. When the ap joins, it will get the new time. The service port address should not be routable on the network and is suggested that you do not connect that to the network.
Scott Fella
Sent from my iPhone
-Scott
Make sure on the management interface you enable the checkbox for ap manger.
Scott Fella
Sent from my iPhone
-Scott
thank you very much. The checkbox for ap manager is enabled.
I  send a picture with the explanation with everything I do, I hope it is easier to understand.
Antonio R.
Muchas gracias por tu ayuda. El cuadro de selección para la administración de AP en la interfaz management está habilitado. Te envío una imagen con una explicación de todo lo que hago, espero que sea más fácil de entender.
Recibe un cordial saludo
Antonio R.
You can't connect the ADSL to the service port.  The LAP1041 needs to connect to a switch and thw WLC port 1 needs to connect to a gigabit switch.  If you want to use the ADSL, then you need to connect that to either a switch and use port 2 or you can connect it directly to the ADSL router as long as it is gigabit.
-Scott
Can you post your show run-config from the cli of the WLC and also the switch?  Is this a managed switch?
-Scott
Hi!
Thanks you very much! Well, the switch is basic, d-link des-1005d, but it's fast ethernet.
I'll look to find a gigabit switch,then i'll comment  how it went.
A greeting
Antonio R.
Hola:
Muchas gracias. El switch es básico, un D-Link DES-1005D, pero es fasteth (10/100).
Buscaré un switch gigabit, y entoncés comentaré como ha ido.
Un saludo
Antonio R.
Can you please post the WLC command "sh sysinfo"?
Hi!
I buy a gigabit switch. I connect the service-port to gigabit switch, and laptop to gigabit switch. I used 192.168.1.x ip address (192.168.1.157 to service-port and 192.168.1.233 to wired port on laptop, well, the laptop has two ip adress, 192.168.1.233 and 209.165.200.2, and the laptop works ok. Ping to 209.165.200.230 -ip address of management interface- and ping to 209.165.200.203 -ip address for AP, is assigned by  DHCP of WLC. And i connect the ap to gigabit switch, and the wlc assigns well an ip direction.
I post the run-config and sysinfo log. The gigabit switch is tp-link model tl-sg1005d, no configuration.
Before the logs, I see this message from AP:
*Apr 19 23:10:20.211: %CAPWAP-3-ERRORLOG: This AP is not supported in controller
version 6.0.199.4  ---->What's mean that? Is it compatible the ap with the WLC? ¿Es compatible el AP con el WLC?
Hola:
He comprado un switch gigabit. Conecto el service-port al switch gigabit y el portátil también (por cable). Uso como direcciones ip el rango 192.168.1.x (192.168.1.157 asignado al service-port y 192, 168.1.233 al portátil, bueno, el portátil tiene dos direcciones, la dicha anteriormente y la 209.165.200.2) El portátil funciona bien, hace ping al 209.165.200.230 - la ip de la management interface, y a 209.165.200.203 - ip asignada al AP por el DHCP del WLC. He conectado el AP al swtich gigabit, y el dhcp del wlc asigna correctamente una dirección ip.
Añado a continuación los resultados de los comandos "show run-config" y "show sysinfo". El switch es un TP-LINK modelo TL-S1005D, sin necesidad de configuración.
Antes de mostrar los resultados de los comandos, he visto el siguiente mensaje en el log del AP:
Un saludo
Antonio R.
(Cisco Controller) >show run-config
Press Enter to continue...
System Inventory
NAME: "Chassis"    , DESCR: "Cisco Wireless Controller"
PID: AIR-CT5508-K9,  VID: V02,  SN: FCW1608L05X
Burned-in MAC Address............................ C4:64:13:8F:93:40
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 25
Press Enter to continue or to abort
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 6.0.199.4
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console
1.27
Build Type....................................... DATA + WPS
System Name...................................... CISCO-CAPWAP-CONTROLLER
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 209.165.200.230
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 17 mins 45 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin,
Rome, Vienna
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... ES  - Spain
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +36 C
External Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 1
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 0
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Network Information
RF-Network Name............................. hosp
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Unicast
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Enabled
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
--More or (q)uit current module or to abort
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
IP/MAC Addr Binding Check .................. Enabled
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE    SFPType
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
5  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
6  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
7  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
8  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A     Not Present
AP Summary
Number of APs.................................... 0
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model             Ethernet MAC       Location
     Port  Country  Priority
AP Location
Site Name........................................ default-group
Site Description.................................
WLAN ID          Interface          Network Admission Control
1               management           Disabled
     Port  Country  Priority  GroupName
AP Config
AP Airewave Director Configuration
802.11a Configuration
802.11a Network.................................. Disabled
11nSupport....................................... Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11a Operational Rates
    802.11a 6M Rate.............................. Mandatory
    802.11a 9M Rate.............................. Supported
    802.11a 12M Rate............................. Mandatory
    802.11a 18M Rate............................. Supported
    802.11a 24M Rate............................. Mandatory
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
802.11n MCS Settings:
    MCS 0........................................ Supported
    MCS 1........................................ Supported
    MCS 2........................................ Supported
    MCS 3........................................ Supported
    MCS 4........................................ Supported
    MCS 5........................................ Supported
    MCS 6........................................ Supported
    MCS 7........................................ Supported
    MCS 8........................................ Supported
    MCS 9........................................ Supported
    MCS 10....................................... Supported
    MCS 11....................................... Supported
    MCS 12....................................... Supported
    MCS 13....................................... Supported
    MCS 14....................................... Supported
    MCS 15....................................... Supported
802.11n Status:
    A-MPDU Tx:
        Priority 0............................... Enabled
        Priority 1............................... Disabled
        Priority 2............................... Disabled
        Priority 3............................... Disabled
        Priority 4............................... Disabled
        Priority 5............................... Disabled
        Priority 6............................... Disabled
        Priority 7............................... Disabled
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC  Status..................................... Enabled
Fragmentation Threshold.......................... 2346
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admision Control (CAC) configuration
Voice AC:
   Voice AC - Admission control (ACM)............ Disabled
   Voice max RF bandwidth........................ 75
   Voice reserved roaming bandwidth.............. 6
   Voice load-based CAC mode..................... Disabled
   Voice tspec inactivity timeout................ Disabled
   Voice Stream-Size............................. 84000
   Voice Max-Streams............................. 2
Video AC:
   Video AC - Admission control (ACM)............ Disabled
   Video max RF bandwidth........................ Infinite
   Video reserved roaming bandwidth.............. 0
802.11a Advanced Configuration
802.11a Airewave Director Configuration
RF Event and Performance Logging
  Channel Update Logging......................... Off
  Coverage Profile Logging....................... Off
  Foreign Profile Logging........................ Off
  Load Profile Logging........................... Off
  Noise Profile Logging.......................... Off
  Performance Profile Logging.................... Off
  TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
  802.11a Global Interference threshold.......... 10 %
  802.11a Global noise threshold................. -70 dBm
  802.11a Global RF utilization threshold........ 80 %
  802.11a Global throughput threshold............ 1000000 bps
  802.11a Global clients threshold............... 12 clients
Default 802.11a AP monitoring
  802.11a Monitor Mode........................... enable
  802.11a Monitor Mode for Mesh AP Backhaul...... disable
  802.11a Monitor Channels....................... Country channels
  802.11a AP Coverage Interval................... 180 seconds
  802.11a AP Load Interval....................... 60 seconds
  802.11a AP Noise Interval...................... 180 seconds
  802.11a AP Signal Strength Interval............ 60 seconds
Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. AUTO
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Min Transmit Power............................. -10 dBm
  Max Transmit Power............................. 30 dBm
  Transmit Power Update Contribution............. SNI.
  Transmit Power Assignment Leader............... c4:64:13:8f:93:40
  Last Run....................................... 75 seconds ago
Coverage Hole Detection
  802.11a Coverage Hole Detection Mode........... Enabled
  802.11a Coverage Voice Packet Count............ 100 packets
  802.11a Coverage Voice Packet Percentage....... 50%
  802.11a Coverage Voice RSSI Threshold.......... -80 dBm
  802.11a Coverage Data Packet Count............. 50 packets
  802.11a Coverage Data Packet Percentage........ 50%
  802.11a Coverage Data RSSI Threshold........... -80 dBm
  802.11a Global coverage exception level........ 25 %
  802.11a Global client minimum exception lev.... 3 clients
Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 600 seconds [startup]
  Anchor time (Hour of the day).................. 0
  Channel Update Contribution.................... SNI.
  Channel Assignment Leader...................... c4:64:13:8f:93:40
  DCA Sensitivity Level.......................... STARTUP (5 dB)
  DCA 802.11n Channel Width...................... 20 MHz
  DCA Minimum Energy Limit....................... -95 dBm
  Channel Energy Levels
    Minimum...................................... unknown
    Average...................................... unknown
    Maximum...................................... unknown
  Channel Dwell Times
  802.11a 5 GHz Auto-RF Channel List
    Allowed Channel List......................... 36,40,44,48,52,56,60,64
    Unused Channel List.......................... 100,104,108,112,116,120,124,
                                                  128,132,136,140
  DCA Outdoor AP option.......................... Disabled
Radio RF Grouping
  802.11a Group Mode............................. AUTO
  802.11a Group Update Interval.................. 600 seconds
  802.11a Group Leader........................... c4:64:13:8f:93:40
    802.11a Group Member......................... c4:64:13:8f:93:40
  802.11a Last Run............................... 75 seconds ago
802.11b Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11b/g Operational Rates
    802.11b/g 1M Rate............................ Mandatory
    802.11b/g 2M Rate............................ Mandatory
    802.11b/g 5.5M Rate.......................... Mandatory
    802.11b/g 11M Rate........................... Mandatory
    802.11g 6M Rate.............................. Supported
    802.11g 9M Rate.............................. Supported
    802.11g 12M Rate............................. Supported
    802.11g 18M Rate............................. Supported
    802.11g 24M Rate............................. Supported
    802.11g 36M Rate............................. Supported
    802.11g 48M Rate............................. Supported
    802.11g 54M Rate............................. Supported
802.11n Status:
    A-MPDU Tx:
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit  ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Legacy Tx Beamforming setting.................... Enabled
Faster Carrier Tracking Loop..................... Disabled
   Video max RF bandwidth........................ 50
802.11b Advanced Configuration
802.11b Airewave Director Configuration
  Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
  802.11b Global Interference threshold.......... 10 %
  802.11b Global noise threshold................. -70 dBm
  802.11b Global RF utilization threshold........ 80 %
  802.11b Global throughput threshold............ 1000000 bps
  802.11b Global clients threshold............... 12 clients
Default 802.11b AP monitoring
  802.11b Monitor Mode........................... enable
  802.11b Monitor Channels....................... Country channels
  802.11b AP Coverage Interval................... 180 seconds
  802.11b AP Load Interval....................... 60 seconds
  802.11b AP Noise Interval...................... 180 seconds
  802.11b AP Signal Strength Interval............ 60 seconds
  Last Run....................................... 213 seconds ago
  802.11b Coverage Hole Detection Mode........... Enabled
  802.11b Coverage Voice Packet Count............ 100 packets
  802.11b Coverage Voice Packet Percentage....... 50%
  802.11b Coverage Voice RSSI Threshold.......... -80 dBm
  802.11b Coverage Data Packet Count............. 50 packets
  802.11b Coverage Data Packet Percentage........ 50%
  802.11b Coverage Data RSSI Threshold........... -80 dBm
  802.11b Global coverage exception level........ 25 %
  802.11b Global client minimum exception lev.... 3 clients
  DCA Sensitivity Level: ...................... STARTUP (5 dB)
  Channel Dwell Times
  802.11b Auto-RF Allowed Channel List........... 1,6,11
  Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10,12,13
Radio RF Grouping
  802.11b Group Mode............................. AUTO
  802.11b Group Update Interval.................. 600 seconds
  802.11b Group Leader........................... c4:64:13:8f:93:40
    802.11b Group Member......................... c4:64:13:8f:93:40
  802.11b Last Run............................... 213 seconds ago
Mobility Configuration
Symmetric Mobility Tunneling (current) .......... Enabled
Symmetric Mobility Tunneling (after reboot) ..... Enabled
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... hosp
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x97e2
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 1
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast
IP     Status
c4:64:13:8f:93:40  209.165.200.230  hosp                              0.0.0.0
        Up
Probe request filtering..........................  Enabled
Probes fwd to controller per client per radio....  0
Probe request rate-limiting interval.............  500 msec
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 2
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
dot11-padding.................................... Disabled
Authentication Response Timeout (seconds)........ 10
Rogue Entry Timeout (seconds).................... 1200
AP Heart Beat Timeout (seconds).................. 30
AP Discovery Timeout (seconds)................... 10
AP Local mode Fast Heartbeat (seconds)........... disable
AP Hreap mode Fast Heartbeat (seconds)........... disable
AP Primary Discovery Timeout (seconds)........... 120
AP Primed Join Timeout (seconds)................. 0
Packet Forwarding watchdog timer (seconds)....... 240 (enable)
Location Configuration
RFID Tag data Collection......................... Enabled
RFID  timeout.................................... 1200 seconds
RFID mobility.................................... Oui:00:14:7e : Vendor:pango  S
tate:Disabled
Interface Configuration
Interface Name................................... management
MAC Address...................................... c4:64:13:8f:93:40
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 209.165.200.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 192.168.1.1
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 209.165.200.230
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
Interface Name................................... service-port
MAC Address...................................... c4:64:13:8f:93:41
IP Address....................................... 192.168.1.157
DHCP Protocol.................................... Disabled
AP Manager....................................... No
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... HOSP3C
Network Name (SSID).............................. HOSP3C
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
  NAC-State...................................... Disabled
  Quarantine VLAN................................ 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
WLAN ACL......................................... unconfigured
DHCP Server...................................... 209.165.200.230
DHCP Address Assignment Required................. Enabled
Quality of Service............................... Platinum (voice)
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11b and 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Learn IP Address....................... Enabled
   Infrastructure MFP protection................. Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Band Select...................................... Enabled
Load Balancing................................... Enabled
Mobility Anchor List
WLAN ID     IP Address            Status
ACL Configuration
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Call Station Id Type............................. IP Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
    Test Mode.................................... Off
    Probe User Name.............................. cisco-probe
    Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
Authentication Servers
Idx  Type  Server Address    Port    State     Tout  RFC3576  IPSec - AuthMode/P
hase1/Group/Lifetime/Auth/Encr
Accounting Servers
TACACS Configuration
Idx  Server Address    Port    State     Tout
Authorization Servers
Accounting Servers
LDAP Configuration
Local EAP Configuration
User credentials database search order:
    Primary ..................................... Local DB
Timer:
    Active timeout .............................. 300
Configured EAP profiles:
EAP Method configuration:
    EAP-FAST:
      Server key ................................
      TTL for the PAC ........................... 10
      Anonymous provision allowed ............... Yes
      Authority ID .............................. 436973636f00000000000000000000
00
      Authority Information ..................... Cisco A-ID
HREAP Group Summary
HREAP Group Summary: Count: 0
Group Name                # Aps
HREAP Group Detail
Route  Info
Number of Routes................................. 0
Destination Network          Netmask               Gateway
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................  75
Silver queue length..............................  50
Bronze queue length..............................  25
Mac Filter Info
Authorization List
Authorize MIC APs against AAA ................... disabled
Authorize LSC APs against Auth-List ............. disabled
Allow APs with MIC - Manufactured Installed C.... disabled
Allow APs with SSC - Self-Signed Certificate..... disabled
Allow APs with LSC - Locally Significant Cert.... disabled
Load Balancing Info
Aggressive Load Balancing........................ Disabled
Aggressive Load Balancing Window................. 5 clients
Aggressive Load Balancing Denial Count........... 3
Statistics
Total Denied Count............................... 0 clients
Total Denial Sent................................ 0 messages
Exceeded Denial Max Limit Count.................. 0 times
None 5G Candidate Count.......................... 0 times
None 2.4G Candidate Count........................ 0 times
Dhcp Scope Info
Scope: PUNTOSAP
Enabled.......................................... Yes
Lease Time....................................... 86400 (1 day )
Pool Start....................................... 209.165.200.201
Pool End......................................... 209.165.200.229
Network.......................................... 209.165.200.0
Netmask.......................................... 255.255.255.0
Default Routers.................................. 0.0.0.0  0.0.0.0  0.0.0.0
DNS Domain.......................................
DNS.............................................. 0.0.0.0  0.0.0.0  0.0.0.0
Netbios Name Servers............................. 0.0.0.0  0.0.0.0  0.0.0.0
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
CDP Configuration
Country Channels Configuration
Configured Country............................. ES  - Spain
      KEY: * = Channel is legal in this country and may be configured manually.
           A = Channel is the Auto-RF default in this country.
           . = Channel is not legal in this country.
           C = Channel has been configured for use by Auto-RF.
           x = Channel is available to be configured for use by Auto-RF.
         (-,-) = (indoor, outdoor) regulatory doamin allowed by this country.
    802.11bg     :
    Channels     :                   1 1 1 1 1
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4
ES (-E   ,-E   ): A * * * * A * * * * A * * .
    802.11a      :                         1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    Channels     : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 5 5 6 6
                 : 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 9 3 7 1 5
ES (-E   ,-E   ): . A . A . A . A A A A A * * * * * * * * * * * . . . . .
WPS Configuration Summary
Auto-Immune
  Auto-Immune.................................... Disabled
Client Exclusion Policy
  Excessive 802.11-association failures.......... Enabled
  Excessive 802.11-authentication failures....... Enabled
  Excessive 802.1x-authentication................ Enabled
  IP-theft....................................... Enabled
  Excessive Web authentication failure........... Enabled
Signature Policy
  Signature Processing........................... Enabled
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Enabled
CustomLogo....................................... None
Custom Title..................................... None
Custom Message................................... None
Custom Redirect URL.............................. None
Web Authentication Type.......................... Internal Default
External Web Authentication URL.................. None
Configuration Per Profile:
Rogue AP Configuration
Rogue Location Discovery Protocol................ Disabled
Rogue on wire Auto-Contain....................... Disabled
Rogue using our SSID Auto-Contain................ Disabled
Valid client on rogue AP Auto-Contain............ Disabled
Rogue AP timeout................................. 1200
MAC Address        Classification     # APs # Clients Last Heard
Adhoc Rogue Configuration
Detect and report Ad-Hoc Networks................ Enabled
Auto-Contain Ad-Hoc Networks..................... Disabled
Client MAC Address  Adhoc BSSID         State              # APs   Last Heard
Rogue Client Configuration
Validate rogue clients against AAA............... Disabled
--More-- or (q)uit
MAC Address        State              # APs Last Heard
Ignore List Configuration
MAC Address
Rogue Rule Configuration
Priority Rule Name               State    Type          Match Hit Count
(Cisco Controller) >show sysinfo
1.27
System Up Time................................... 0 days 0 hrs 41 mins 2 secs
Rome, Vienna
Internal Temperature............................. +39 C
The AP log
AP442b.03dc.0925>
*Apr 19 23:10:18.428: %CAPWAP-3-ERRORLOG: Selected MWAR 'CISCO-CAPWAP-CONTROLLER
'(index 0).
*Apr 19 23:10:18.428: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Apr 19 23:10:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 209.165.200.230 peer_port: 5246
*Apr 19 23:10:19.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Apr 19 23:10:20.200: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
peer_ip: 209.165.200.230 peer_port: 5246
*Apr 19 23:10:20.201: %CAPWAP-5-SENDJOIN: sending Join Request to 209.165.200.23
*Apr 19 23:10:20.201: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 19 23:10:20.354: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 19 23:10:20.355: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 209
.165.200.230:5246
*Apr 19 23:10:20.356: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Apr 19 23:10:20.412: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is
not established
You just found the solution to your problem.  You need to use WLC firmware 7.0.98.0 (and later) so the WLC can support the 1040 WAP.
Thank you! I try to download the firmware. But i need "BID" (?), and i don't know the steps to uptade the wlc.
¡Gracias!, después de tres días me doy cuenta de eso. Intentaré descargarme el firmware, pero necesito un acceso especial, el ¿BID?, aparte de que no sé como actualizar el WLC.
