300
Highlighted
Beginner
config ap max-count is not working Code 8.3
I'm using a Controller code 8.3 but the command below is not working:
config ap max-count count
1 ACCEPTED SOLUTION
Beginner
Re: config ap max-count is not working Code 8.3
I opened a case with Cisco TAC team and the Configuring Maximum Number of Access Points to be Supported could not be configured anymore from the CLI and GUI (number is directly related with the license count).
I Tried to use the command several platforms and versions (8.2, 8.3, 8.5) and it is really not supported.
The TAC said that it's no plan to be implemented in future releases.
The TAC team sent a feedback to the team that updates the documents ,but there is no ETA for the changes
4 REPLIES 4
Beginner
On the Guide, says it's possible to configure:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-3/config-guide/b_cg83/b_cg83_chapter_0100.html?bookSearch=true
(Cisco Controller) >show ap max-count summary
Incorrect usage. Use the '?' or <TAB> key to list commands.
(Cisco Controller) >config ap max-count 25
Rising star
What WLC and code version 8.3.? are you running?
For the show command can you do:
show ap maximum
I cant see this feature work in 8.5.x or 8.2.x
The command was only added i believe 7.5.x and above maybe they removed it
Post the output of:
show license capacity
Details on the config ap max-count command:
You can configure the maximum number APs that can be supported on a controller. The controller limits the number of APs that are supported based on the licensing information and the controller model. The maximum number of APs supported that is specified in the licensing information overrides the number that you configure if the configured value is greater than the licensed value. By default, this feature is disabled. You must reboot the controller if you change the configuration.
What are you trying to actually use this command for? There might be another way to do it
There is another post showing someone not finding the command in 8.3.143: https://community.cisco.com/t5/wireless-and-mobility/how-to-change-maximum-allowed-ap-on-virtual-wlc/td-p/2516294 so thinking they might have removed the command but haven't updated the doco
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Beginner
I'm running 8.3.143.The commando is not working on that version:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.143.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
The command you asked:
(Cisco Controller) >show ap maximum
Max APs Supported................................ 75
Max AP Groups Supported.......................... 500
Max AP join limit................................ 75
(Cisco Controller) >show license capacity
Licensed Feature Max Count Current Count Remaining Count Remaining Capacity
AP Count 75 0 75 75/75
"What are you trying to actually use this command for? There might be another way to do it"
I want to monitor the license usuge via monitoring tool.
On the Guide below related to version 8.3 says it's possible to configure that comand:
Fiz o teste também na versão 8.2 e não funcionou da mesma forma:
Product Version.................................. 8.2.160.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
(Cisco Controller) >[
Beginner
Content for Community-Ad
July's Community Spotlight Awards
