06-01-2011 05:45 AM - edited 07-03-2021 08:16 PM
Hello everyone,
I'm a beginner in the world of wireless, and I wonder if in a WLC 2125, I need to configure a physical port to the AP Manager or just need to configure the AP Management and AP Manager will automatically accept.
I am awaiting response,
Tks a lot,
Eduardo Cesaro
06-01-2011 06:17 AM
The below link will answer ur question!! Lemme know if this helps..
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70mint.html#wp1117288
Please dont forget to rate the usefull posts!!
Surendra
06-01-2011 06:37 AM
this document does not solve my question
I already have tried MAC Filter with AAA, but it seem, that thre is no forward to the aaa server
What I try to do is this:
- PC tries to get a connection to a WLAN
- WLC forwards the MAC address to the AAA server
- AAA server sends back the VLAN ID
- WLC will switch the WLAN to the WLAN#ID
Like MacAuthentication bypass at a switch
Udo
06-01-2011 07:45 AM
Udo,
that answer is outside the scope of this particular question, but....
What you are looking for is AAA Override. This must be enabled on the WLAN(s) that you want to use. THen on your ACS/IAS you can use options 64/65/81 to set the VLAN ID or the interface name that you want the client to be in.
Cheers,
Steve
If this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
06-02-2011 06:28 AM
Gentlemen,
I appreciate the help, but the best help , i found in follow document; https://supportforums.cisco.com/docs/DOC-11760
Tks
Edu
06-02-2011 06:38 AM
Thanks Edu, that is Indeed good document by Lee. Don't forget to rate and comment good content on CSC .
thanks,
Vinay
