08-27-2012 11:34 PM - edited 07-03-2021 10:35 PM
i forget the console admin password for acs 5.3 which is installed on vmware ,but am able to login through gui mode,
so is it possible to change username and pwd for console administrator through gui,if it is how to do that ?
Please help on this
By
Veeramani.G.
Solved! Go to Solution.
08-28-2012 01:43 AM
You can not reset console password from GUI. The console CLI is for the appliance and that password is not accessible from the application GUI.
You need the recovery DVD and you can reset the password then.
Here is the procedure: http://tiny.cc/k4sqjw
Amjad
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
08-28-2012 01:43 AM
Amjad
