08-27-2012 11:25 PM - edited 07-03-2021 10:35 PM
i need to configure ntp on acs5.3 ,i dont know how to configure through gui mode,
Please help this on urgent basis
by
Veeramani.G
Solved! Go to Solution.
08-28-2012 01:23 AM
Hello Verramani.G,
You can not configure the NTP on ACS 5.x from GUI. It can only be done from CLI.
The CLI provides basic configurations to the appliance AND some configuration to the application running on it (which is ACS).
The configuration of the NTP is only done on the appliance configuration, not on the application configuration.
So, the only way to configure the NTP server is from the CLI.
Thats why you can find the ntp server configuration on the CLI reference command of ACS 5.x, not on user guide or config guide.
CLI reference guide: http://tiny.cc/r7rqjw
Amjad
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
08-28-2012 01:23 AM
Hello Verramani.G,
Amjad
