Highlighted
Beginner
Configuring 881W wireless
I'm having trouble configuring my router for wireless. I have followed guides but with no luck. Right now my issue is below with the radio. I cannot figure out why this is stuck in reset. I have reloaded the AP with no luck. Any suggestions? Config is posted below.
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       10.20.50.35     YES DHCP   up                    up
Dot11Radio0                unassigned      YES NVRAM  reset                 down
GigabitEthernet0           unassigned      YES NVRAM  up                    up
GigabitEthernet0.2         unassigned      YES unset  up                    up
CONFIG
########################ROUTER#######################
Current configuration : 5422 bytes
! Last configuration change at 18:55:56 PCTime Wed Feb 29 2012 by msetnes
! NVRAM config last updated at 18:37:40 PCTime Wed Feb 29 2012 by msetnes
version 15.1
no service pad
hostname XXXXXX
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
memory-size iomem 10
clock timezone PCTime -6 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
ip source-route
ip dhcp excluded-address 10.20.30.1 10.20.30.99
ip dhcp excluded-address 10.20.50.1 10.20.50.31
ip dhcp pool LOCAL
   import all
   network 10.20.30.0 255.255.255.0
   default-router 10.20.30.1
   dns-server 8.8.8.8 8.8.4.4
ip dhcp pool WIFI
   import all
   network 10.20.50.0 255.255.255.0
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
username XXXXXX privilege 15 secret 5 XXXXXXXX
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 1
bridge irb
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description "Connection to internet"
ip address dhcp client-id FastEthernet4
ip flow ingress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface wlan-ap0
description "Service module interface connecting to embedded AP"
ip unnumbered Vlan2
arp timeout 0
interface Wlan-GigabitEthernet0
description "Internal switch interface connecting to AP"
switchport trunk native vlan 2
switchport mode trunk
interface Vlan1
description "Local"
ip address 10.20.30.1 255.255.255.0
ip flow ingress
ip nat inside
interface Vlan2
description "Wireless"
ip address 10.20.50.1 255.255.255.0
ip flow ingress
ip nat inside
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 23 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 dhcp
logging esm config
access-list 22 remark
access-list 23 permit 10.20.30.0 0.0.0.255
access-list 23 permit 10.20.50.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
exec-timeout 5 0
transport input all
transport output all
end
#########################AP##########################
dot11 ssid XXXXXX
   authentication open
   guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid SkyNET
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip default-gateway 10.20.30.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
privilege level 15
login local
line vty 0 4
login local
end
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Configuring 881W wireless
not the AP, but that one too. The GW in your dhcp scope is showing the wrong IP
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
8 REPLIES 8
when you define the VLAN under the SSID you need ti create the sub interface under the radio as well.
If your only going to have the one SSID the you can remove the VLAN from under the said and encryption statement.
Steve
Beginner
Thanks, this brought the radio back up. I seem to be connecting and disconnecting consistently. Is there something I'm missing in my config?
EDIT--
I removed encryption just to resolve this issue for now. My issue now is I am not able to talk outside of the wifi network. I can only ping within the 10.20.50.0 network.
nothing I'm noticing of the top of my head. Can you be more specific with the issue? Do you get an up address the drop or do you not get that far?
Beginner
I receive an IP address (10.20.50.36) I can only ping this wireless IP within the AP and router, nowhere else.
check your GW address according to your scope it's 10.20.30.1 which is VLAN 1. It should be 10.20.50.1 the VLAN 2 address.
Steve
Beginner
I've corrected the default gateway on the AP to no avail. I still cannot talk between wireless and wired clients, as well as not being able to reach outside the network with WiFi.
Beginner
Removing the VLAN and encryption statements under dot11 ssid resolved the connecting issue
Changing the DHCP scope default router to 10.20.501 resolved the communication issue.
Both networks can talk now and both and reach externally.
Thanks Stephen, much appreciated.
Content for Community-Ad
August's Community Spotlight Awards
