Community Helping Community
1224
Highlighted
Enthusiast
Configuring IR829 as wireless client bridge.
Hello Experts,
Is there any user guide for specifically configuring IR 829 as wireless client bridge?
When I log into the device, I am into the normal router prompt. To configure it as an wireless client bridge do I need to get into ap specific prompt?
1 REPLY 1
Beginner
Hi Adnan,
Hi Adnan,
Are you talking about ISR (Integrated services router) 829 ? If yes, this will be a good start to configure and understand the device:
http://www.cisco.com/c/en/us/td/docs/routers/access/800/829/software/configuration/guide/IR800config/access-point.pdf
Hope this helps,
Manish
Content for Community-Ad
August's Community Spotlight Awards
